Question about Sharp R-230 Microwave Oven
The touched keypad of the mic rove doesn't work and the round inside it rounded always... what may be the problem and who we can reset the system if it has problem ???!!!!
  • 1,557 Answers
There is no reset if the keys are not working is an ic chip problem and the microwave would be cheaper to replace than to have fixed
sorry
good luck
Posted on May 15, 2010
Do you sell the inside round glass tray and the round wheeled thing you place it on?
At fixya, we do not have a warehouse of parts, manuals, ect. We work at home answering questions only. You have to contact the manufacturer for parts.
Sep 14, 2015 | Microwave Ovens
Microwave wont work
Call the manufacturer about resetting the electronics. If not possible the board needs to be replaced if the price is right.
check here Search Over 2 1 Million Appliance Parts
Sep 08, 2017 | Sharp Microwave Ovens
Microwave plate will not go round when it is working
There is a drive motor mounted underneath the plate.This probably has failed
Dec 01, 2012 | Microwave Ovens
Sharp Carousel Model R-209KK-W is flashing all 8's and keypad not working
The first thing to try is to do a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still doesn't work, it may need repair, which can be done for $39.95 in most cases.
Jun 10, 2012 | Microwave Ovens
Kitchenaid vented microwave KHHS179LSS-5 surface light is blinking on and off. Started a couple of weeks ago. Thought I was forgetting to turn the light off but realized it was not me. Went to the...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Apr 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The keypad works; the microwave can be turned on and turntable turns round, the light is on, the motor sounds (a little louder than normal) but no heat can be generated. What could be causing this?
No heat would mean the magnetron circuit has failed. It's the part that generates the microwaves that heat the food. If it is making a loud buzzing noise, it could mean that the magnetron or the high voltage diode has failed. Since there exists high voltages inside the oven, would require a qualified service person to repair. However, if the magnetron has failed, would recommend buying a new oven since the parts alone can cost as much as a new oven.
Dec 06, 2010 | Microwave Ovens
I have samsung microwave model number ME 1240SC. my front panel touch screen is not working properly, when i press the keys it is not working. so i think i need to replace the touch screen. so please...
That model does not user a touch screen, it actually uses a standard membrane keypad.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then try it again.
If it's still not responding, I would suspect your membrane keypad has failed.
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you wanted to order a new membrane switch / keypad, the part number is DE34-00145F and you can order it from the Pros here. They're our favorite supplier.
Otherwise, this is a pretty standard 1200W microwave, and you may find it better to simply replace it instead of repairing it.
Dec 03, 2010 | Samsung Microwave Ovens
GE Spacemaker appears to be sparking inside/top
1.Needs to remove that disk and clean the grease under it.
2. With sand paper clean dark burn spots.
3. Apply touch paint on open metal spots.
4.Put everything back.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
F3 light comes on the front panel and microwave does not work
F3 means a shorted keypad.
On this model (assuming it's JVM1320WB02) the repair cost would run about $115 if we do it for you. We regularly repair these for customer nationwide.
If you prefer to do it yourself, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Full details of our service are at http://www.microwavedisplay.com but if you still have questions, please reply to me directly via my site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave start button doesn't push in to start my microwave
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
It's most likely that the keypad is worn out or possibly you have a flaky door switch.
We have full details, critical safety, disassembly, and troubleshooting info (as well as door switch testing info) at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually order Samsung parts (either the keypad / membrane switch or control panel with keypad) from http://www.samsungparts.com but that model number is not showing up, so you may have to call or e-mail them through their site.
Dec 27, 2007 | Microwave Ovens
Sharp R-230 Microwave Oven Logo
73 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
