Kenmore clothes washer top loading
I would like to replace hot water mixing valve on model #110-82872120 and can't seem to get top off. spring clips on tight and I'm afraid of snapping them off
  • 109 Answers
Use a this blade putty knife to push spring clips in while pulling on corner of top. sometimes can be a near. no worries though you can repair the bent clips if they get messed up easily.
Posted on Mar 30, 2008
    President:
  • 1,314 Answers
Get a big screwdriver and jst pop the out wont break spring steel just reamber haw they hook to the washer and just popem back in when done
SOURCE:
Kenmore 70 won't let in any hot water.
Check to see if there is power going to the hot water solenoid.
If there is power,then replace the mixing valve.
Dec 24, 2010 | Kenmore 24032\24036 Top Load Washer
When control on warm or hot no warm or hot water comes out, just cold
The problem is a bad hot water solenoid on the water inlet valve (also known as a mixing valve). There is a separate solenoid for hot and cold water. If the hot water solenoid fails, you will not have any warm or hot water. Replacement is simple and inexpensive. The following link explains how to access and replace the inlet valve on a Kenmore top loading washer:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service. Prices vary between them so shop and compare.
If you have any questions about this repair, or have need additional assistance, please post back with your complete model number (located along the wash tub rim under the washer lid). I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool, so these instructions do apply.
Dec 10, 2009 | Kenmore 22422 Top Load Washer
My Washer is only filling with hot water and cannot complete the rinse cycle because hot water is not an option.
You may have a defective cold water solenoid on the water inlet valve. There is a separate solenoid for hot and for cold. Since nearly all washers use cold water only during the rinse cycles, you are correct, the washer will not complete a full cycle. You will need to replace the inlet valve. The following link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
This is a very simple and inexpensive repair. The average cost is about $30-$35. A replacement can be purchased at any of the following websites:
repairclinic.com
If you need further assistance, please post back with your complete model number (located under the wash lid along the tub rim), so that I may be able to provide you with better service. I hope this helps you.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Water not hot on hot temperature setting
BS ....on the back inside the washer are two solenoid operated valves that control the hot and cold water flow. your hot valve has ceased to function...and needs replacement.  also make sure your hot water valve is open fully and that the screen inside it isn't clogged.
Mar 29, 2009 | Kenmore 22422 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Disassemble Washer
Here ya go. Follow the steps provided in this link:
The mixing valve is also know as a "fill valve" or "water inlet valve", just for clarification. I hope these steps help you with completing your repairs. If you get confused along the way, or require additional assistance, please let me know.
Dec 22, 2008 | Kenmore 24032\24036 Top Load Washer
Need to get into the water mixing valves on Whirlpool washer
with putty knife press in clips at each corner of console and lift up ..also press same type clips at front edge of top about 2-3 ins in from each corner
Nov 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Hot water wont shut off
solenoid valve is jammed open
replace
Mar 31, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
