Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Won't move I have a craftmans LT2000 it will start but won't move backwards or forward just hear a whirring sounds what could problem and do I add transmisson fluid
    Top Expert:
  • Craftsman Master
  • 13,764 Answers
Check drive belt and tension pulleys under machine if belt is stretched or damaged replace if popped off pulley check all to make sure one has not froze causing it to pop off also check rear pulley on axle sometimes pops off and just spins
Posted on May 15, 2010
  • txsheldons May 28, 2011
    is freewheel control engaged. Did you pull out the rod in the back. If it is not pushed back in the mower will start but won't move.
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
2000 ford windstar transmisson will not move forward
You have a failed forward clutch, time for a rebuilt.
Jan 06, 2013 | 1999 Ford Windstar
2009 impala driver side power seat won't move up/down, makes whirring sound when attempted. Moves forward backward. Passenger seat works properly.
Before you do any of the expensive things disconnect and reconnect the wiring to the seat I had the same exact problem with my 2009 Chevy Impala and was ready to take it to the dealer when I disconnected the power cables to it and reconnected them I found that one of the Harnesses was loose and the problem was solved
Sep 12, 2012 | 2009 Chevrolet Impala
Turn the key and hear a whirring sound, serpentine belt wont move and car won't turn over
In every likelihood have the Bendex of the checked up. It is not connecting the self starter motor with the engine crank shaft thus the whirring sound.
Apr 02, 2012 | 1995 Chevrolet Camaro
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftman 19 HP riding lawnmower - used Model 944607192 My question is how do I adjust cutting blade depth since I do not have a manuel
There should be a long lever to your right when seated, move that lever forwards and backwards for height adjustment. Good Luck...
Aug 16, 2011 | Garden
Sears Craftman LT2000 does not start
bad safety switch one under seat ,clutch pedal,blade engage leaver
Sep 01, 2009 | Garden
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
1996 Mercedes SL Power seat problem
hi,seat motor are in maximum length,try to seat,then apply force backward also the switch in backward mode.
Feb 16, 2009 | 1999 Mercedes-Benz E-Class
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
568 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
