Question about Neff B1641 Single circotherm super Electric Oven
There is no power or light at all on my Neff oven. The hob is still working fine. Do you have any suggestions as to what I should do?
    Sergeant:
  • 228 Answers
Is the clock flashing 00.00???
Posted on May 29, 2010
3 Suggested Answers
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
barkencoa
  • 3463 Answers
SOURCE: Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
Posted on May 21, 2010
What size cable and fuse do I need to run a Neff oven 3.68kw. and induction hob 7.2kw together ?
Divide the total load by the volts available ie. 11kw by 240v or 110v, the result is current in amps. You need a cable of a suitable cross section to transmit that amperage. There is also a distance calculation to be considered as this affects the available load. Get a sparkie to guide you as to correct sizing.
Nov 04, 2014 | Neff Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Do all neff oven & hobs have to wired in using 6mm cable or can they be wired into a13 amp system
If it is a single oven on it's own then it can be used from a 13 amp plug and socket, the same with the hob, if it is seperate from the oven it can be used from a 13 amp socket.
If it is a combined unit, then it will have to be hard wired to a seperate circuit using 6mm twin and earth cable, and fused on it's own circuit.
Nov 07, 2010 | Neff B1421 Electric Single Oven
May 21, 2010 | Neff B1421 Electric Single Oven
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Jul 15, 2009 | Ovens
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
No Instruction manuals
Down load them from Neff.
http://www.neff-home.com/uk/service/manual
Then you can print them.
Aug 04, 2017 | Neff Ovens
NEFF HOB
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate. If you can locate the device, using a metal shield to divert some of the heat will help it serve its original function as a safety. Look for a thick (4-5 mm), button-like device with two terminals and a diameter of 1.5-2.0 cm.
This point of failure is shared with a majority of drip coffee makers that fail way too early.
Oct 18, 2008 | AEG B1180-4 Electric Single Oven
FAN OVEN NOT WORKING
power went off to the house now cant reset fan oven on hotpoint bs21
May 23, 2008 | Ovens
Neff B1641 Single circotherm super Electric Oven Logo
384 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
