Question about Hitachi 42HDS69 42 in. Plasma Television
Hitachi 55 inch plasma won't turn on - green power light is on and sounds like screen clicks to come on but no picture appears
Fujitsu
  • 29 Answers
SOURCE: hitachi 55 s69 plasma
Do you have the menu on screen??
If you dont have image, maybe you need change the Y-Sus PWB and the SDR´s
Posted on Nov 28, 2008
dgjtex
  • 405 Answers
SOURCE: screen went black while watching, no sound
Almost for certain your power supply board is bad, Can be repaired at the component level only if you have some electronics savy! Good Luck!
Posted on Dec 26, 2008
dsacco86
  • 1077 Answers
SOURCE: Powers up but picture doesn't appear.
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Posted on Jul 08, 2009
jhinsincity
  • 616 Answers
SOURCE: Hitachi Plasma P50S601 no picture sound OK
probably needs new scan drive board along with upper and lower buffer boards. it wont be cheap and its best to have a tv shop do it.
Posted on Aug 30, 2009
  • 1267 Answers
SOURCE: have a 55 inch hitachi plasma tv. The picture
Seems as if your high voltage power supply went kaput. This happens sometimes see the complaint
at: http://hitachi-home-electronics.pissedconsumer.com/hitachi-55hds69-plasma-tv-20100417178696.html
See: http://www.partstore.com/Model/Hitachi+Ltd/Hitachi/55HDS69.aspx for a list of parts and you can see if it is worth fixing
Posted on Dec 01, 2010
Hitachi 55" plasma: No picture, no sound
Perhaps the seller forgot to mention the basic power supply problems and who knows what else
Jun 12, 2013 | Hitachi 55HDS69 55 in. Plasma Television
I have a hitachi 55pma550 plasma tv.when I turn on the main switch red light comes on standby. But when I turn on tv the red red light on stand by turns green only for 10 seconds and goes red no picture...
It's most likely the smps. You'll first need to check voltages at CN63, pin #1-(+5v), 3-(+3.3v) and pin 8-(+6v) Also check CNPPS, pin 1-(+30v), 4-(+5v), 8-(+12v), 12-(+10v) absent these values and the power supply is clearly the problem.
Jun 30, 2011 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
When i turn the power on my 55 inch plasma tv, my screen stay black no picture
If you take the back off you might see a couple of electrolytic caps that might be bulged on the power supply board. The power supply board is getting weak, and if you replace the electrolytic caps that will fix the problem. You can also replace the power supply, and you can check at www.partstore.com for a power supply.
Feb 14, 2011 | Hitachi 55HDS69 55 in. Plasma Television
42 inch hitachi plasma
the more the tv remains on the picture gets out of focus mainly in the midle of screen. Sure sounds like tv needs some light engine repair or replacement.
Aug 11, 2009 | Hitachi 60V500 60" Rear Projection...
Jul 08, 2009 | Hitachi Televison & Video
Hitachi 55hdx62 no picture
Anyone have issues with the HDMI input on this TV no longer functioning?
Jan 15, 2009 | Hitachi 55HDX62 55 in. Plasma HDTV
Screen went black while watching, no sound
Dec 26, 2008 | Hitachi 55HDT79 55 in. Plasma HDTV
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Red box half way down screen
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
Jun 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 42HDS69 42 in. Plasma Television Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
