Question about Whirlpool AWM6120 Front Load Washer
I don' can open the door - Whirlpool AWM6120 Front Load Washer
  • Whirlpool Master
  • 43,501 Answers
Check out this tip that I wrote, it will tell you how to get into the washer manually...
Washing Machine Door Jammed
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
Posted on May 15, 2010
Mi driver side door don`t open from out side or inside
Sounds like the door is either still locked or there's a problem with the mechanism inside. Probably have to take the handle apart
Aug 08, 2014 | Pontiac transport lock. door lock. rear...
Freezer is Frozen shut
Try unplugging the freezer and leave the door open for about 30 to 45 minutes. Don't forget the door is open and plug the freezer back in. Set a timer in the kitchen so you don't forget. Once you can open the drawers look inside the freezer sides to find the controller. Most models have turn dial inside.
Mar 07, 2012 | Siemens Freezers
Driver side door won't open
If the door handles feel like they have resistance but don't open the door I would suspect a seized door latch.
Dec 30, 2011 | 1995 Chevrolet Suburban
Chamberlain hd400 open force setting at max. Just installed. Will only open door with open force at max setting. Door appears to be balanced fine. No obstructions noticed.
If you release the opener from the door and operate the door by hand it should be obvious if there is a door problem. If it is in warranty you can call Chamberlains technical support line at 800-528-5880. Double check that model number before you call. They don't recognize it.
Oct 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
2003 chevy tahoe heat and air fan runs with key off
does it still stay on after you open the driver door?, the tahoe keeps power going for a while or until you open the door, you can listen to the radio without the key on if it was on at the time you turned the vehicle off, i don't know how long you owned the vehicle you probably already know about the door killing power with key off. you'd be surprised at how many people don't know that have them/
Sep 26, 2011 | 2003 Chevrolet Tahoe
2004 Pontiac Montana, when I open my drivers door the radio doesn't always shut off any more, I opened the passenger door & it shuts off, I think it's a door pin switch but I don't see a...
You don't find much with the door jamb switches any longer. Its all done inside the door with the switches being on the door latch.
the radio should still be able to be turned off manualy ;)
Aug 24, 2011 | 2004 Pontiac Montana
Our Samsung J1455AV door won't open, just over a year old. Have cleaned the filter, re-run a cycle, turned off at wall. Help!
Hi
Thanks for using FixYa. To start with if the door lock is stuck and wont unlock then you can pry it to open, and just don’t try too hard. The issue can be with the door latch that is stuck, to unlock it you can stick a flat screw driver behind the door latch and then lever it to open so that you don’t have to pry it to open. Once it’s done, please make sure to replace the door latch assembly to avoid any further issues. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 12, 2010 | Washing Machines
Craftsmen garage door opener 139.53919 door spring split in two and garage door will not open
Have someone out to fix the spring.
DON"T fix it yourself. These things are very dangerous and can cut off fingers or worse. Just Google replacing garage door springs to read up and the danger replacing these can be.
Have someone who know what they are doing fix it.
Jan 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
If the head light doors don"t open the lights don"t come on how do I get the doors open
the lights should come on whether or not the doors are open,they are powered by the headlight switch at the same time the switch powers the lights
Dec 02, 2009 | 1991 Chrysler New Yorker
Whirlpool AWM6120 Front Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
