Question about Garden
Engine no longer stops when keyed off
I just replaced the coil (35135/35135A) on my Sears (917.254630) riding mower. It starts and runs great but when you turn off the key, the engine stays running. Any thoughts?
  • 474 Answers
Most small engines incorporate a ground wire that makes contact when the key is put to the off position. check to ensure that the wire is hooked to the switch and in the correct position
Posted on May 15, 2010
Testimonial: "Can't find a good wiring diagram so this was a big help. Thanks"
How can I replace a lost ignition key for a Craftsman LT2000 riding mower
the model number is under the seat on a sticker most riding lawn mowers use the same key the older models used one the looks the same on t=both sides and was short the newer style is longer and has cuts on one side only most any lawn mower shops will have them
Jun 14, 2012 | Craftsman Garden
No spark on sears riding mower
sounds like you might have a bad coil
Jun 11, 2012 | Garden
John deere model240 mower will not start. Have replaced coil and still not getting spark at the plug . Engine turns over strong
Only option left.... 12 volts feeding coil is not there. The ignition key applys the 12 volts to the coil in the "Run" and "Start" positions. Verify 12 volts at input to coil and then (if needed) follow wire back to key and confirm voltage there....and (if needed) follow input wire to key from battery. One of those critters is open - since you have already confirmed the coil/spark plug wire is not at fault.
Dec 15, 2011 | John Deere Garden
I read the guys problem with his Cub Cadet running and then stalling out. Here is my problem with my lawn tractor; I have an older model 125, runs great but stops running after about 30 min. when it...
My name is Dane and I am going to help you solve your problem.
Run your mower again and when it starts to run rough, loosen your gas cap. If it runs right again, you have a stopped up gas tank vent. clean it or replace the cap. Could be a bad coil too. I hope I've helped! Thank you! Dane
Dec 28, 2010 | Garden
Tractor dies
my lx173 quits running after a while and will start back up and run for a while longer and quit again
May 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Sears riding lawnmower.14hp??
The coil is bad. The coil is gettin hot and shorting out .
Aug 22, 2009 | Garden
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Apr 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
