Question about Rainbow E series Canister Wet/Dry Vacuum
The power cord is split near the base unit
The cord is split near the base unit causing the unit to cut on and off with an occasional spark. I can fix the cord but need to take the chassis apart to get to where the cord connects to the unit. The split is so close to the base I can't splice it. The problem is I can't see any way of getting the chassis apart.
    Sniper:
  • 52 Answers
There are 2 screws on each side of the top cover of the Rainbow ‘E’ series vacuum cleaners located behind the decal windows. To get to the screws; use a non-scratching tool such as a plastic putty knife and pry out a corner of the plastic window, carefully pull out the plastic window and decal and remove the 2 screws. Repeat this process for both windows and then just lift up the top cover to expose the inside.
Posted on May 17, 2010
My Hoover Wind Tunnel(UH71250) 4 mts old while vacuuming the cord become hot at the same time it shut off and wont turn back on. Checked for all clogs none No red is showing on indicator how can I fix
That suggests that there was a bad/loose connection in the cord that couldn't carry the needed current. It heated up and burned its way through the wire. Replace the cord, or if it was hot near the plug, cut it back and add a new plug, available at most hardware stores.
Jun 05, 2018 | Hoover Vacuums
Miele silver moon s558 powers up sometimes not others, very light use, all filters clean, will not power up with power head attched or not. Is there a fuse to change? Is there anything a home owner novice...
That's remarkably good news. You can almost certainly fix it for about twenty cents in about twenty minutes. First, open the main bag chamber, and remove the upper bag chamber lid. This can be achieved by gently prying back the tabs back by the hinges, and then sliding the whole thing upward. Next, you'll want to remove the exhaust filter and the two screws holding the control unit to the back of the vacuum. (The black part.) Lift up at the front of the control unit and it should lift away. This may make a terrifying snapping noise, don't worry about it. You didn't break it! Next you'll need to remove the screws that hold the main chassis onto the base. I believe there are roughly seven, in a perimeter around the chassis, if memory serves. Note that there are a couple up by the handle part. Once they're all removed, the whole thing should lift right off. Now, here's the actual cause of your problem. Over time, the cord reels in these guys start to wear out a little bit, and what happens is that the electrical contacts that keep power flowing through your reel start to move apart from each other. Locate the cord reel, which should be hanging out in the base area. Grab the white reel itself and wiggle it left and right. See all that play? So here's the fix: get a ziptie from an auto parts store or any place like that. Remove the screw holding the cord reel assembly into the machine and lift out the cord reel. When looking at the reel, you should be able to see the electrical leads that come out of the center of the wheel: one black, one white. On the OPPOSITE side of the reel from those wires, you're going to want to put the ziptie around that central axle. This will then take out all that slack you were feeling. Make sure you clip the end of the ziptie before you re-install your reel. Place the cord reel back in the body and then make sure you re-thread the cord through the hole in the back of the chassis. Place the chassis back on, replace the screws. Place the control unit back on, and replace the screws, snap the chassis lid back in, replace your bag and filter, and you should be in business. Please note that this works 99% of the time, but occasionally a reel will wear out to the point where this fix won't work. If it does, you do now know how to install it, so you shouldn't have to pay anyone else to do it for you. A new reel costs about $120, which is why I ALWAYS tried this fix first. Also of note: I wrote these instructions from memory, so if you're trucking along and you find that I've missed something somewhere, post another clarification request and I'll walk you through it. Good luck! -R
Sep 23, 2011 | Miele s558 Silver Moon Vacuum
Sebo Vacuum runs intermittently and keeps cutting out and restarting
There could be numerous reasons for this. What I would try in this order to help troubleshoot is this:
1. If you wiggle the power cord near where it inserts into the vacuum cleaner itself, does the vacuum turn on and off constantly? If so, you have a damaged cord or loose connections that need to be fixed.
2. Has the bag been emptied, and if the vacuum has a filter element, has this been cleaned? Vacuums may cutout if they get too hot. A vacuum can overheat if either the bag is full, the filter is blocked, or there are other obstructions to airflow, which cause the motor to work harder and draw more voltage, resulting in more heat. It may have a thermal cutoff which is tripping constantly. Solution is to ensure bag is not full, or less than 3/4 full, any air filters are cleaned and check for any other obstructions in the air flow paths.
3. Ensure the power supply is adequate for the vacuum. Try running it without long extension cords if you have been using those.
4. Check and clean the switch. Sticky or dust contacts on switches can cause variable cycling (cutting out and restarting).
Hope that helps!
Mar 11, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Lately, my Kirby Ultimate G has been acting funny. When I push it forward, it's fine, but when I pull it backward on the carpet, the light on the front flickers and the power flutters off an on. I...
The cord will need to be replaced with a cord made for the machine, as it has a non-standard plug. The cord cover is held in place with a # 20 Torx screw. Remove the screw and push the cover gently from behind to unlatch it. The handle must also be removed, along with the switch "scuff" plate. To remove the rear plastic trim plate, remove the screw at the bottom rear, and the upper screw holding the cord to the motor shell. The upper screw is a # 15 Torx screw. To remove the trim piece, insert a flat screwdiver into the rectangular slot in it and pry it upward. Reverse this proceedure to install the new cord.
Feb 07, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Occasionally when vacuuming the carpet there is a burning smell from the vacuum that I can't figure out where it's coming from. The base of the vacuum also gets hot. Should the vacuum be serviced? Is...
It is the belt in the beater bar.
Turn over the vacuum and remove the screws in the bottom of beater bar and split open the casing
The belt is either worn and slipping or pulleys are wrapped with debris causing the smell
Please let me know if this helps
Jan 20, 2011 | Vacuums
Sebo has become erratic in electrical power and today I have sparking from the top of the electrical lead where the wire goes into the handle. Can this be fixed?
yes it can be fixed.
If you are handy or someone in the house is handy you may even be able to do this yourself.
All that is required is to remove the one screw out of the handle there near where the cord goes into the machine. Cut the cord off the unit about 2 inches from the handle.
Open up the handle and follow where the cord goes to, and disconnect the cord from the switch. Both the white and the black will go to the switch.
Feed the cut cord through the handle.
Bare off about 1 and 1/2 inches of the cord you just cut, bare off the black and white and replace onto the switch.
Reassemble everything and you should be ready to rock and roll again.
Good luck.
Mark
Nov 11, 2010 | Sebo X4 Bagged Upright Vacuum
Trouble engaging the on switch for both suction and to drive the roller on a Hoover Savy windtunnel (bagless).
The electronics in the handle are constantly going out. First things first though, recline the unit and turn the vacuum upside down so the front is resting on the carpet. Locate the black wired which is near the nozzle and body, wiggle that cord while the vacuum is on to test. if it cuts out, that is your problem if it doesn't replace the top handle and that will fix your unit
Aug 26, 2009 | Hoover U6630-900 WindTunnel Bagless...
When turning on the unit blows the fuse every time
you need a 60amp to run this have a quilified elec in stall
Feb 12, 2009 | Polti Vacuums
Bissell 6595-1 with broken electrical connector
YES! If you haven't contacted Bissell yet (or bought a new vacuum) do so. They sent me a nice refurbished machine for free.
Dec 12, 2008 | Bissell 6595 Lift Off Bagless Upright...
Steamer #410 has cord problem
u can send it back or u can fix it urself its a simple fix all u have to do is check the power cord going in u can cut about an inch n reattach it and it should work good luck
Nov 16, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
212 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
