Question about Dishwashers
My matsui mtt4w dishwasher is leaking water and displaying error E1. Any ideas?
SOURCE: E1 Error Message
Just had the same problem.It is a common defect of the standard pump motor assembly and LG recognises it and sells the whole assembly for $38. They changed the type of motor and now is 120W instead of the original 45W. They also supply a modified bracket to fit the new motor.
Posted on Jul 30, 2007
  • 110 Answers
SOURCE: E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Posted on Dec 27, 2007
SOURCE: E1 Error on LG Dishwasher (LD-2040WH)
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
Posted on Aug 13, 2008
SOURCE: Lamona dishwasher from Howdens. E1 code
I had the same problem with my dishwasher. I ended up pulling it out and i noticed that the hose that feeds it water had been folded. I then restarted it and it worked fine but juse to test I turned off the water supply and there it was E1.
So in short, E1 is no water feed.....
Posted on Aug 14, 2010
  • 3 Answers
SOURCE: LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
Posted on Nov 07, 2010
My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
Sep 25, 2015 | LG Dishwashers
E1 error on Baumatic BAD6003
If you are getting E1 error then the dishwasher is suggesting that water is getting in but not enough. But if you are getting no water into the dishwasher then the water inlet valve inside it is faulty. Have you checked if there is water inside the dishwasher when you get E1 error. Another thing to find out is the water pressure specification of dishwasher and whether it is consistent with the mains pressure in the house. Usually there should be a plate on dishwasher door which would give water pressure required.
Apr 20, 2014 | Baumatic Dishwashers
Displays E1 code. water is on
Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
E1 code comes up on the display, but how do you solve this? ...
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Feb 18, 2010 | LG 24 in. LD-12BW5 Free-standing...
Lg intellowasher dishwasher gives error 1 on all cycles
If it's 00:E1. You need to check the water level sensor, and the thermistor.
If the display is E1. then you need to check for water leaks, or restrictions inside the impeller inside the pump.
Dec 23, 2009 | Dishwashers
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Lg dishwasher lds 5811st E1 error code
Hi Chaz,
The impeller breaks on the motor shaft. The motor still turns, but the impeller doesn't, so it doesn't pump water. Because the machine senses there is no water pressure from the pump, it shuts down & displays E1 (it thinks there's a water leak, due to no pressure)
Unfortunately the motor/impeller is only available as a complete assembly
Hope this helps
Col
Dec 11, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Lg dishwasher model LD - 14AT2
E1 is usually a very common fault of the wash motor not working.
The impeller breaks away from the motor shaft and doesn't spin, therefore, it doesn't pump water.
There is a sensor that activates with low pump pressure, which shuts down the machine and displays the error, E1.
The only other causes (that I'm aware of) are leaking water supply hoses, or pump blockage, but the motor fault is by far the most common.
Hope this helps.
Mar 18, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dec 23, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
130 people viewed this question
Top Dishwashers Experts
