Question about Lexmark X644e All-In-One Laser Printer
I have Lexmark x644 when I turn on the printer only 5 hear repeated sounds
  • Official Brand Answer
  • 3,344 Answers
Check this link to the Lexmark website and I hope it's just caused by a loose cable connection. http://bit.ly/aQ5dsb. Just follow the instructions carefully. But if problem is not resolved, it may require service. If that's the case, I strongly advise you to contact Lexmark Technical Support for further assistance. Hope I can assist you more on this.
Posted on May 17, 2010
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
SOMEBODY CAN WE HELP US? WE HAVE A PROBLEM WITH DUPLEX LEXMARK X644.
If you mean that you are getting a ghost image of the letterhead on the page this is caused by not setting the paper type to letter head which caused the temperature to be wrong and print does not bond. Or you may have a bad fuser or bad toner cartridge. Try setting the paper type to letterhead or bond first to see if that helps.
Aug 07, 2014 | Lexmark X644e All-In-One Laser Printer
Hello, i have the Lexmark X342N the machine will recieve the fax store it to memory, but it will not print the fax. Toner was low and could be the problem. (replaced toner) How do I print the recieved...
Please try to do the following steps
1 From the control panel, press Fax.
2 Press Menu.
3 Press up or down button repeatedly until REPORTS is selected.
4 Press the check button
5 Press up or down repeatedly until Fax Call log or Fax Job log is selected.
6 Press the check button to submit
For further assistance, please contact Lexmark Technical Support.
Feb 22, 2011 | Lexmark X342n All-In-One Laser Printer
Wrong language on the LCD display of the Lexmark X6570 how do I fix?
Select a different language after initial setup
1 From the control panel, press Settings.
2 Press left or right arrow repeatedly until Device Setup appears.
3 Press tick.
4 Press left or right arrow repeatedly until Language appears.
5 Press tick.
6 Press left or right arrow repeatedly until the language you want appears on the display.
7 Press tick.
8 Press left or right arrow until Yes appears.
9 Press to save.
Hope that helps, if it does please rate my help. Thanks
Nov 03, 2010 | Lexmark All-in-One Printer with PictBridge
Printer connected to computer i am trying to fax it says i must intall drivers
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
From
Tech Expert
Jeethu
Sep 08, 2010 | Lexmark X7350 All-In-One Printer
Paper feed jams continually. I hear a repeated clicking sound at the time of each jam like the paper is trying to feed without success.
sounds like tthe first time it jammed power was on and someone pulled agains the tide forceing the removaly and stripping the transporter gears. Need to look inside and see if there is plastic gears looking stripped
Jul 29, 2009 | Lexmark X5150 All-In-One InkJet Printer
I am unable to send faxes or recieve faxes
2. Press "Menu."
4. Press "Select."
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark Z600 printer, get an unable to cimmunicate with the printer, I get a power light and have checked the usb cable same msg. repeats
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Feb 21, 2009 | Lexmark Inkjet Z517 Photo Printer
PAPER FEEDER SOUND AND LIGHT IS BLINKING
when you turn it on, the ink cartridge holder should be moving left to right (aligning itself). make sure the cartridges are insterted correctly and that the clasps are all the way in.
Jan 10, 2009 | Lexmark Z600 InkJet Printer
Lexmark X644e All-In-One Laser Printer Logo
370 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
