Question about Weber Genesis Silver B Grill
Flame is low output - Weber Genesis Silver B Grill
  • 494 Answers
Try turning off the tank, disconnecting it, reconnecting it and very slowly turning the tank valve back on. You might have turned the gas tank on too fast, causing the excess flow flow to check, only allowing a trickle of gas through to the burners. If that doesn't fix it, click on my username and scroll down my profile to my tips and tricks for gas grill lighting issues. Hopefully one of the tips listed will solve the problem.
Posted on May 16, 2010
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Why won't the pilot light stay lit?
You have a "pilot generator" that sits in the flame of the pilot light. This generates a low voltage output from the flame of the pilot light. This voltage goes to the gas valve and tells the valve that the pilot is lit and to keep the pilot gas line open.
In almost all cases replacing the pilot generator will resolve the issue . They run about $60-$75.
Other causes may be the gas valve itself or a short in the safety loop, in either case should be looked at by a pool tech.
Jul 10, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
It only gives low flame upon starting and cannot
close your air vent on the burners it will increase the height of the flame
Mar 27, 2010 | Grilling
Country flame nps-1000 made in 1996 has a lazy flame, low heat output, and having a difficult time regulating auger feed any suggestions
not getting enough air -clean and vacuum unit and check fresh air flow damper is not opened enough need more air or flue clogged and needs cleaning
Feb 15, 2010 | Napoleon Auburn Pellet Stove Heater
Kitchenaid 30'' low flame output
It's wasn't the perfect solution but I removed all the burner caps and cleaned each one with a tooth brush. Then using a metal trussing pin, I poked through the flame holes to clean them. Noticed better flame output from both.
Mar 06, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Low flame signal
There is an L-shaped wire in the back by the flame that is the flame sensor you can take it out and take fine sand paper or emory cloth and try cleaning it
Dec 05, 2008 | Goodman GMS80904BNA Open Flame Mid-Size...
Heater not staying lit
This from the installation manual on your furnace.
I think you need check the flame senor for proper output. if the output is correct you wil have to switch the electronic board.
FLAME SENSOR (QUALIFIED SERVICER ONLY)
Under some conditions, the fuel or air supply can create a nearly
invisible coating on the flame sensor. This coating acts as an
insulator causing a drop in the flame sense signal. If the flame
sense signal drops too low the furnace will not sense flame and
will lock out. The flame sensor should be carefully cleaned by a
qualified servicer using emery cloth or steel wool. Following cleaning,
the flame sense signal should be 1 to 6 microamps at 115
volts.
Post me back and let me know.
Dec 01, 2008 | Goodman Heating & Cooling
Weber Genesis Silver B Grill Logo
257 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
