Question about Franke Saphira Espresso & Coffee Maker
Franke Flair Coffee Machine. Hot water button stopped working last week. Now all the coffee selection buttons have stopped working. Have cleaned and descaled the machine. When I press to select a coffee there is no noise at all. Display is saying ''select product'' Any assistance would be appreciated, Scott Ceramics Cafe farnham@ceramicscafe.com
5 Suggested Answers
  • 4 Answers
SOURCE: Franke coffee system, always same error message ''fill water tank''
What you would have to do is take the side panel off to get at the solenoid. It is probably sticking closed and not letting the water fill into the boiler.
Posted on Mar 21, 2009
  • 29 Answers
SOURCE: our franke flair coffee machine keeps saying
this is usually due to the overtemp device activated on one of the thermoblocks, an engineer will be required to replace this item,
Posted on Nov 19, 2010
mikey270
  • 26 Answers
SOURCE: I have a franke flair coffee machine when you
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Posted on Jan 29, 2011
  • 242 Answers
SOURCE: Hi, my Franke Flair does not respond when I push any of the buttons to make coffee, water, milk etc. it just displays the 'SELECT PRODUCT' message. The rinse, clean and descale buttons all work.
Unplug unit to reset the settings completely...If you have the same problem call manufacturer to save time...
Posted on Apr 05, 2015
How often do we change water filter
The filter should be replaced at the intervals recommended by Franke.
Aug 15, 2016 | Franke Flair Espresso Machine with...
My franke flair coffee machine will not power up
the two main reasons for this are the on off switch located on the back of the machine is switched off. the other is the flap to the grinders is not correctly fitted. other than this an exporative visit by an engineer may be required. there are two mains fuses situated by the cable inlet behind the rear panel.
Apr 26, 2014 | Franke Flair Espresso Machine with...
Franke flair trips the electric when turned on
It might be good idea to disconnect the coffee valve and switch on machine as it's 230v and might be shorted and tripping and blows fuses.If it is then replace brew valve.
Apr 13, 2014 | Franke Saphira Espresso & Coffee Maker
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
How can I get different size lattes and cappucinos with my Franke Flair? all it gives me is a shot size serving...
enter programme button.push and hold for 5 secs.machine will show def product. press programme again to confirm.select product comes up on screen.press the product you want to adjust eg espresso.now use the + and - buttons to scroll through the espresso setting. if you want to adjust anything in the settings, you need to press programme. then make the adjustment with the + and- buttons then press enter when finished the actual adjustment .once finished with the espresso and happy press exit button.repeat the process for the next button. you can down load a manual at franke .com
Aug 17, 2010 | Franke Saphira Espresso & Coffee Maker
System fill message
Then it is a problem with the flowmeter. This needs to be changed, please contact your local dealer.
Aug 13, 2009 | Jura Capresso Impressa S90 Espresso...
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
Mar 20, 2009 | Coffee Makers & Espresso Machines
Franke Saphira Espresso & Coffee Maker Logo
184 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
