When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
The usual reason for oven doors not closing properly, is weak door hinges,if it does not close all the way, and the door seal is o/k, then I suggest you replace both door hinges.
Thamks.
