Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
My hp f1903 is blurry and I can´t get it to focus. I´ve tried the sharpness on the monitor menu button and have it at the highest level but it does not help.
  • 11,361 Answers
You should try setting your PC video resolution to the native resolution of this monitor, 1280 x 1024 @60Hz.
If it still bad then you may need to open it up and inspect the inside for bad parts such as capacitors, burnt marks, etc.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 16, 2010
Hp f1903 flat pc monitor goes black after 5
I was given a faulty f1703 by someone as it was out of warranty, had no help from HP and bought another brand replacement.
Same problem everyone else seems to be having. Press the on button, came on for a second or so and then went blank. Press button again, turn on again and the same happened.
I managed through trying time and again after pressing on to quickly press menu, then go down to Factory settings, press select, go down to Yes and press select again. This reset to the Factory settings and it seems to be working okay. Been like this now for about a week. I don't know how long it will last - if it goes again will try re-soldering. Guess I won't be buying HP products as this was a part of a very expensive system.
Apr 29, 2010 | HP W2007 LCD Monitor
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My monitor is stuck in a constant color loop...
What you are seeing is a test they use at the factory. Here are the instructions to reset the monitor:
1. Press the MENU button
2. Use the + and - buttons to choose Advanced Menu
3. Press the SELECT button
4. Select Factory Reset
5. Select Yes
6. Press MENU again to remove the onscreen menu
Hope that helps :)
Dec 13, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
Blur
Well, that's a general statement. If you are looking to have the image look like a HDTV then you have the wrong impression of the projector's capabilities. At 800x600 resolution you will get a "good" but not great image especially if compared to a tube tv or plasma/lcd. If the graphics are sharp when you press the menu key then you probably do not have an issue. If, however, even the graphics are blurry, then you have to manually adjust the Grey outer focus ring on the lens. The inner ring will adjust the zoom. Hope this helps.
Feb 15, 2008 | InFocus X1A DLP Slide Projector
Focus is way off...screen is blurry????
is the monitor a flat screen? if so, you can try the autoadjust button, which is found by pressing the monitor menu button, and cycling through.
Jan 06, 2008 | Acer X221WSD Monitor
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
