Question about Franke PF3000Series Deck Mounted Pot Filler Faucet with Two Valves....
Leaking franke pullout faucet
How can I find leak and repair...wrench size?
broii4x4
  • 13 Answers
SOURCE: Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Posted on Mar 24, 2009
  • 68 Answers
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Posted on Apr 12, 2009
SOURCE: I have a franke filtered water faucet and it is leaking
I have a similar problem and while I've gotten further along than you have, I still don't have the complete solution. The little "ceramic" disk that says "Franke" on the knob does come off. It's just well glued on and requires destroying two x-acto blades and putting some large chips in the logo disk to get off. Once you get the disk off you'll discover that the knob requires a special tool to remove. I haven't been able to locate one but usually when you buy a replacement washer/gasket set it will come with the special wrench to remove the fastener from inside the knob. So if you locate a faucet repair kit for that faucet, let me know!
Posted on Aug 07, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
SOURCE: water leaking from bottom part of the faucet
I had a similar problem with my relatively new Forte model. I disassembled the handle, removed the retaining ring and the valve assembly. I thought at first it was the valve assembly but wasn't convinced. I continued to remove the entire faucet hub by gripping and pulling straight up. When I did, the diverter valve popped out of the back to the counter behind the sink. I cleaned all the parts up, made sure all the rings were in place, presse the diverter securely into place back in its hole, and reassembled the rest of the parts. That seemed to do the trick. I'm guessing that the diverter lost its seal and was displaced inside the hub. Hope that helps someone else.
Posted on Oct 27, 2010
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: FortĀ® Single-control...
I also have a Franke 200 series faucet and it's leaking where pullout spray attaches to supply tube after replacing washer....is it possible for sprayer hose to leak...its silver not just a nylon hose
Although I am unfamiliar with the name "Franke", I am more than familiar with this problem.
I have had it too many times to count.
I have discovered it takes an assortment of black rubber/plastic washers to fix this.
I even have them in my tool box for this very problem.
Not enough washers will cause a leak, too many and the hose will not ***** on.
I have had to experiment with different washers to get the fix.
God bless your efforts.
Apr 04, 2016 | Franke Plumbing
K-12177 leaking around top
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 24, 2013 | Kohler K-12177-G Fairfax single-control...
I have a Franke faucet in my kitchen. (It has 3 levers - Hot, Pure and Cold). The faucet developed a slow leak. I tried to tighten the screws on all 3 levers and broke 1, so I have to replace it. To...
The cause of leaking is the ceramic gasket. Yes you can replaced it. Find your local hardware store then buy a repair kit for that faucet. If you can bring the sample bring it.
Please rate my help.
Thanks for using fixya.
Jan 10, 2011 | Microwave Ovens
How do you remove aerator from franke pullout faucet ff-200?
A small crescent wrench should do just fine. Just be careful not to cross thread when putting it back on.
Jan 28, 2010 | Plumbing
Mar 28, 2009 | Franke Plumbing
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
Franke PF3000Series Deck Mounted Pot Filler Faucet with Two Valves.... Logo
172 people viewed this question
Top Franke Plumbing Experts
Donni Steen
ray gallant
William Wurtinger
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
