Question about HP Pavilion dv6000 dv6100 dv6200 dv6300 dv6400 Motherboard - 434722-001
My dv6000 dont start . i have black screen with one long beeb and two short beebs
    Sniper:
  • 123 Answers
Heat vga chip
Posted on Jul 13, 2010
I have a constant beeb beeb ----beeb beeb---beeb beeb from my speakers or headphones but not from the computer tower when the speakers or headphones are removed. Is this a audio problem with PC or a virus?
Hi there
A couple of points.
Many system boxes no longer have built in speakers, and if they do they are very simple and simply used for POST errors and other alarms eg CPU fan failed, overheating etc. If there is a pattern to the beeps, you need to check against your BIOS codes to ensure nothing serious is happening.
If your system is working completely normally otherwise, then I would suspect an audio problem, which might be resolved by removing and re-installing the audio driver from the disk supplied.
Cheers
Nov 10, 2014 | Computers & Internet
The dial tone is going beeb, beeb,beeb,beeb,but the phone is working ok,its like there is messages but it does not have answering machine
You may be subscribed to a voicemail system provided your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 15, 2012 | Lands Phones
Beeb codes
Beeps usally video related,,,ddr cards,,try removing one ,,with off ,,,then restart cpu,,see if helps,,if not repeat,,same with next ddr card,,,after putting other card back,,could be bad card,,good luck
Dec 20, 2011 | Dell Alienware Aurora-R3 Gaming Desktop...
HI friend,
one long beeb and two short beebs Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information,some couse of that issue is New hardware conflicting with old hardware or New hardware conflicting with old hardware or Connections not connected or connected properly or other hardware issue.Best solution is
If any new hardware has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.Remove any disks, CD's, DVD's that are in the computer and if any USB devices (ipods, drives, phones, etc)
before all that please
Make sure all fans are running in the computer. If a fan has failed (especially the fan for the CPU) your computer could be overheating and/or detecting the fan failure causing the computer not to boot.
If you continue to to receive the same problem with all the above hardware removed attempt to disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
  1. Re-insert the memory into the same slot.
  2. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  3. Try one stick of memory in each slot.
Thanks,
Please rate me.......
Apr 04, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
That code means that the display adapter is bad. Replace the display card.
Mar 23, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hp dv9260nr 4 beebs, black screen. can i fix or replace video
from what i know about laptops, their VGAs cannot be replaced because they are built into the Mobo so the best solution there is to consult a laptop techinician. He could just reinsert or clean the contacts that could cost cheaply.
Sep 23, 2009 | HP Pavilion dv9260nr Notebook
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
FIC FR33E long beeb ?
Take out your memory modules and reseat them. One of them may not be in all the way.
AWARD BIOS BEEP CODE ERROR - 1 Long Beep - Memory Problem (Module not seated well)
May 15, 2008 | FIC FR33E Motherboard
Problem withPanasonic phone
Unplug the power supply to the phone, wait 1 minute and plug it in again
Mar 05, 2008 | Lands Phones
TV won't stop beebing
Now I am not a expert in this field by any means and there may be someone else that can give you a better answer but I will provide some insight from experience. When this happens it is usually do to the television going into protection mode, this is to let you know something is wrong inside the T.V., it does this to prevent any further damage to the T.V.. I do not know but if it is still under warranty you should read your warranty paperwork and contact whoever it tells you to, if it;s not then you should contact your nearest T.V. repair shop.
hope this helps
Carl
Feb 07, 2008 | Televison & Video
HP Pavilion dv6000 dv6100 dv6200 dv6300 dv6400 Motherboard - 434722-001 Logo
197 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
