Question about Oreck XL2200 Bagged Upright Vacuum
Vacuum dead I have oreck XLx2 bagged upright - the belt ,plug and cord have been replaced - has been working great - now went to plug it in and it does not work - the light goes on in the on/off switch so power is working but vacuum is dead - any suggestions
  • Anonymous Mar 23, 2014
    Can't find bags for this vacuum.
  • 1,673 Answers
If the cord coming from the bottom up to the handle is loose, and is a plug, push it in. If that doesn't help. then could be a problem with the motor. One other thing to check is inside the handle, maybe a wire came loose.
Posted on Mar 30, 2008
Suction problem
Probably have a clog some where in the base and that is what causes it to throw stuff back out.
Apr 04, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Upright vacuum cord is broken
Hello, this is Ava with Think Crucial,
It looks like you may need to replace your power cord. My suggestion is to call Oreck at 1-800-442-8604 and see if they can help you out with replacing your power cord.
You can also purchase other replacement parts for your Oreck vacuum such as Roller brush, belts, or even vacuum bags directly through us. Please click on this link to see our Oreck parts for your model:
As a special offer here is an exclusive 10% coupon for readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Jul 21, 2012 | Oreck XL2000 Bagged Upright Vacuum
I have an Oreck XL 2310RS. What bag number do I need for it? Thanks.
All oreck uprights take bag type CC. I would Recommend buying oreck brand bags. they have the only patton on the bags. off brand bags will work but they will leak and tear and break.
Sep 08, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Have an Oreck XL upright, when switch turned on no "Power" checked receptical and power supply is OK
What typically happends is if the vacuum falls over the cord will come disconnected from the switch.
there are 6 screws on the handle if you unscrew them the handle will seperate down the middle. you will see a few wires in there. the whites wires should be wire nuted together while the black wire from the long cord, the side that you plug in to the wall, would plug on to the top of the switch, unless you have a 2- speed vacuum the it also would plug into the top but on the prong that is closes to you. it will make sense when you open it up. there is another cord that come up from the base of the vacuum to the handle which is called the up cord. the black wire that comes from that plugs in to the bottom of the switch.
if that doesnt work then you might have a short in your cord that will need to be replaced or your motor could have gone bad. and oreck motor typically last about 8 to 10 years.
if more problems occur i would recommend bringing it to and authorized Oreck dealer. If your vacuum is under warranty it will be fixed for free.
Sep 05, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I was vacuuming and the vacuum just stopped running. The cord is fairly new so I know it isn't that. Any suggestions?
Sometimes when the small pipe from the motor fan gets plugged up the motor will overheat. For safety reasons, the motor shuts off. If you able to start up the vacuum later, and the suction is not great, then follow the owner's manual to unplug the hose. It is not difficult, but it does require disassembly of the sweeper part of the vacuum. Make sure that you unplug the machine before you try to make any repairs. I have had to do this myself on occasion when the vac seemed to lose suction power. Another problem might be that you vacuum bag might be too full.
Since you mentioned that the cord is fairly new, I will make the assumption that you replaced the cord. If that is the case, then make sure the cord is unplugged from the wall, and check the connections of the cord to the vacuum. One of the wires might not have been attached properly and worked it was loose. This can happen especially if you pull hard of the cord when vacuuming. Oreck's come with a fairly long cord, but you still have to plug into a socket when you run out of cord.
If either of those suggestions does not work, then I recommend a service call to a local repair center.
Jul 16, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Not working  I hit the switch and there is no sound of a motor.  Nothing is happening.  It was working seconds earlier and suddenly it stopped.  The plug was in and I replugged it into...
If it was just a broken belt you would still hear the motor running. most likely its in your cord or switch. check the main cord, connections to the switch, and also the motor supply cord that goes from the handle to the vacuum head.
Feb 26, 2010 | Oreck XL Ultra Bagged Upright Vacuum
My oreck XL7 smells when it's on. Smells as if it's the motor. Had the Oreck for 4 years but hardly used it?
The smell is probably from the belt. When they are worn and stretched they can start to smell. You can get replacement belts for your model here:
Oreck XL7 Replacement Belts
Nov 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck Vacuum Cleaner problem (upright)
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Aug 30, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
153 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
