Question about Motorola Mobility W375 Cellular Phone
My phone won't charge. I have plugged it into a
My phone won't charge. I have plugged it into a wall jack and a computer jack. I still have 2 bars left on the phone so it is usable for now but when I try to charge it it doesn't charge.
  • 36 Answers
It's either you charger is damages or the mouth thing or your phone is damaged.
Posted on May 15, 2010
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
My ereader isn't charging properly
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 05, 2012 | Sony Reader Touch PRS-600
My device won't charge
This situation sometimes occurs when the batteries get overcharged. Use the phone for a day and then attempt to charge. If it still won't charge, remove the battery for about a minute. Then re-install the battery and attempt to charge. If that doesn't clear the problem, you may need to get a new battery.
Mar 03, 2012 | Motorola Mobility T505 Handsfree...
I am trying to hook up my digital answering system with a multi line phone. I need step by step what I need to do. Thanks Ivy Hutchison
The answering machine would plug into the telephone jack on the wall, and the telephone would plug into the jack on the rear of the answering machine.
Now you do mention that the telephones are multi-line units. This could complicate things a bit because the 1739 is a single line answering machine.
If the telephone does not have individual jacks for each line (a jack for line 1 and another jack for line 2) you would need to purchase an adapter (maybe 2 of them...depending on the wall jack) that takes a 2 telephone lines and splits them into 2 individual jacks.
For example:
http://www.tti.net/computer-telephony/phone-accessories.html
After the lines have been broken out, you can connect the answering machine to the line that needs it. You would then either plug the lines into their respective jacks on the wall, or use a 2nd splitter to combine the 2 lines back at the wall jack.
May 23, 2011 | AT&T ATT1739 Digital Answering Machine
Just got a HTC incredible s and i plugged it in to charge and the phone shows no signs of charging. help!!!!!
I would take the USB cord and plug it into your computer and charge it that way. There has been some trouble with the wall charges coming with phone not working. If it still won't charge, its time to take it back to were you got it. Good Luck!
May 17, 2011 | HTC Wildfire Cell Phone
I am having problems setting up the phone cords. what all do i need to plug in my fax machine
You should only need the power cord and a phone line. My Brother has 2 jacks for the phone line. One is a line in, (from the wall jack to the fax machine), the other is a line out, (for you to plug in a dial up computer connection or a second phone). Make sure you have the cable from the wall jack plugged into the line in, plug.
Jan 30, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
When I plug the cord from the wall into my computer the internet works fine. When I plug from the wall into the phone the phone works. However when I plug from the wall to the phone to my computer the...
mcdevito75 here, You cannot access the internet and make a phone call also unless you have DSL. You can get an adapter for your phone line. This adapter will go into your phone jack and be able to hook up 2 phone lines, 1 to your computer internet and 1 to your phone, however you"ll have to dis-connect from the internet to recieve or make a call, and if your on the phone you can"t get the internet. This phone jack adapter is available in Radio shack or even some dollar stores. You can of course make a phone call with a cell phone while connected to the internet.
Jun 29, 2010 | Cisco 7912G IP Phone
switch charger to different wall outlet, turn off phone, and let it charge completely before using again.
Mar 23, 2010 | Motorola Mobility W375 Cellular Phone
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
My phone is dead
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
Motorola Mobility W375 Cellular Phone Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
