Question about LG WM-2277HW Front Load Washer
Lgwm2032hw does not drain once tub gets full. how
Lgwm2032hw does not drain once tub gets full. How do I trouble shoot without calling a service tech?
  • 343 Answers
The first thing to do is to empty the washer by allowing the water to flow out of the drain hose by gravity...If it won't flow you have a blockage and you'll have to check the pump filter which is accessed via the small door at floor level (or behind the kick plate) Unscrew the pump cover and check the filter..Water can and will flow out if you haven't emptied the washer. There may be a small hose which next to pump cover which allows controlled draining....Good luck....Nomess
Posted on May 15, 2010
Kenmore oasis elite dryer trouble shoot f-24 error kenmore
According to the manual, follow these steps:
  • For an "F" error on your Washing Machine.
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select DRAIN & SPIN if there is excessive water in the washer.
  • Re-select cycle and press START.
  • If the problem remains, call for service.
Here's the full manual: Kenmore 110.45986400 Owner's Manual
Jun 15, 2014 | Kenmore Elite 45986 Front Load Washer
Lasco bubbler massage tub
Sounds like you may have a circuit that is bad in the control box under the tub.
Very unusual for that type of issue unless there is a problem on the circuitry.
Call a technician to have them trouble shoot it for you. It may need to be replaced. Those are not usually an item that is fixed.
Rod
US Parts Center
Feb 02, 2014 | Jacuzzi Nova Whirlpool Tub H532
DRAIN DIRECT
You have to be sure the tub drain can handle the volume of water from a full load without overflowing and the drain is not likely to get clogged
Jul 10, 2013 | Washing Machines
The wash water will not run out
Not sure what model you have but there are a few reasons water will not drain. Assuming your pump is not bad, try emptying your drain filter. You will need to access your washer's cabinet to do this. See if you have a drain filter located between the bottom of your tub and the pump motor. Some of these are usually pretty good size, around the size of a tennis ball. Important: See if there is a shut off valve between your tub and the filter, if so you will need to turn it off prior to removing the filter. If not, you will need to hand bail any excess water from out of your washer tub. Once you remove the filter for cleaning, any water left in your tub will run out unless you have that shut-off turned to off. Clean the filter out thoroughly, put it back in and be sure to turn the shut-off back to the on position. If this is not the problem or your model does not have a filter, repost back here with your exact model number and I will trouble shoot further.
Nov 26, 2010 | Maytag Washing Machines
I have a haywood s220t top mount filter unit, when in filter select water shoots out the drain line any help would be great.
Thank you for posting your question here on Fixya.com.
You need to replace the gasket inside the valve to stop the leak and then run the pool using just the main drain until you can get more water in. The gasket kit is pretty cheap and not to hard to replace. We can try to get you the part number if you can post the valve brand and model. You should be able to call any local pool store with the brand of filter and get the part you need without any trouble.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Aug 25, 2010 | Hayward S220t Top Mount Pro Series Sand...
My washing machine is having trouble getting past the rinse cycle. I checked the hose made sure it was secure and clear of any debris hair etc. Then tried to resume draining but once it starts back up it...
YOUR PROBLEM IS DOOR SWITCH OR CLOGED DRAIN PUMP THER SHOULD BE A ACCESS PANEL FOR THE DRAIN PUMP SO YOU CAN GET TO THE PUMP AND UNSCREW THE OUTLET TO UNCLOG DRAIN
Apr 26, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag M# fav6800aww top loader major problems
Marco;
You have a Clutch malfunction read this post Clutch Fix. You may be able to get away with just a Clutch One-Way Roller bearing clean up and re-lube. What are the first two numbers of your Serial Number it will be 10 thru 17?
That is your Series number. Series 10 and 11 from what little feedback I have received from FAV6800A/FAV9800A owners use the upper bearing ring you will see described in the Clutch Fix post.
Here is where the Serial number is located if you haven’t already observed. Thank you for calling out your model number. This board is structured very poorly for not asking up front info of model number and serial number. Let me know if I can help…..Rich
Mar 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Open small door lower left corner then unscrew and check pump filter. With filter out, start a drain cycle and verify pump turning OK.
Mar 23, 2010 | LG WM-2277HW Front Load Washer
Maytag dishwasher will not drain water - remains in bottom of tub
Without a proper model number, it sounds like either the drain pump is defective or something is stuck in it or the drain tubing is clogged. Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Dishwashers
Bosh Dishwasher not filling
I had the same problem with no water coming in. Each model may be different, but i solved the problem by holding down the clean drain button for 5 seconds. On my model, it is two buttons simultaneously, then closed the door and waited for the washer to cycle through. Once completed, turn off and then back on again to run normal load. If this does not help. Call Bosch Directly. They have an excellent customer service desk (1-800-944-2904) or http://www.boschappliances.com/kitchen-appliances-dishwashers_dishwashers_Integra_800-series.html.
Hope this helps
Aug 21, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
LG WM-2277HW Front Load Washer Logo
82 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
