Question about Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
I have a Hasqvarna 150BT blower that started to make a knocking noise at full power and has lost some power. Seems to start ok. Loss of power / rpm and knock are only ploblem?
I had the same issue with a Husqvarna 150 BT blower. Brand new ran through 2 tanks of gas and need to buy more gas , mixed 50 to 1 ratio 87 octane on new gas which was the same as what i was running and it started pinging and running like **** then stalled and would not start. took the plug out and it was fouled. cleaned the plug got it running again but still not good. This model comes with a NGK CMS7H plug which i replaced with a champion RZ7C and new gas 93 octane and lawnboy oil mixed 50 to 1 ration and now its running like a champ. I've had bad experiences with NGK spark plugs in the past and thought this may resolve the issue and it did. Hope this is helpful to anyone out there having the same issues. Also used some fuel stabilizer in the fuel mix, I hear this helps with the ethanol problem in the fall/winter gas.
Posted on Nov 06, 2012
Try using fresh fuel oil mix 50:1 use higher octane gas, your engine may be pinging or detonating
Posted on Oct 12, 2010
2 Suggested Answers
  • 2468 Answers
SOURCE: I have a Hasqvarna 150BT blower that started to
sounds like either a rod bearing or a wrist pin loose on the crankshaft or on the connecting rod
Posted on Mar 23, 2010
What can make an engine start knocking? it has not over heated, there's
You should be able to use a long piece of rubber hose to listen around the engine and find the source of the noise. I am assuming you have checked oil pressure.
May 20, 2014 | 2002 Ford Mustang
Loss of acceleration and shaking/knocking noise
Could be one of your coil packs is faulty. Get it plugged in to check codes. Not expensive and easy DIY if it is.
Apr 20, 2014 | 2001 BMW X5 3.0i
My Husqvarna 150BT leafblower was running great then started to loose power like when I run out of gas, I shut it off check fuel level which was fine, cleaned the air filter, added more fuel and pulled the...
Pull the muffler and look for scoring on the piston. I think you cooked it my friend. You may have a bad coil or fuel cap, but it's more likely you ran the mix too lean.
Nov 04, 2013 | Husqvarna 150Bt Leaf Blowers
My loyale starts and runs ok, but makes a terrible noise, coming from the engine area. It sounds like a very loud knocking, clicking, sort of sound. It doesn't seem to affect the running of the...
hi a loud noise like the one you described can really only be a few things, either the main engine bearing is getting worn and is on its way out or you have a damaged or dirty lifter. The main difference between the two is the bearing will sound like a knock or grinding noise and the lifter will be more like a loud tick from either the left or right head on the motor you may just have to listen carefully to tell but it is possible and they will both speed up with the engine rpm. A bearing will usually cause problems running/starting/idling etc so maybe lean towards a lifter if it is damaged it will need an expensive replacement but try an oil change first as this can also free up dirt etc and solve the prob
Jun 02, 2011 | 1991 Subaru Loyale
2-cycle blower starts up but wont run full power rpm
Have you tried choking it about half way and see if that helps? Does it do the same after it is warmed up?
Mar 11, 2010 | Homelite Consumer Products Backpack...
Leafblower
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Oct 18, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
90 Toyota 4Runner pinging noise
hi the pinging you here is ignition firing before it should but if you have a knocking noise i would suspect the worse but try doing a compression test first see if everything is in order then if this seems ok have you put fuel in it just before it started if so change your fuel if not see if the electrical system has a knock sensor if so run the engine and tap the block close to it see if engine revs drop if not replace but the knock is a piston best of luck yates210456
Oct 12, 2008 | 1990 Toyota 4Runner
Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt Logo
1,689 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
