Question about Dishwashers
Frigidaire Aquasurge, panel is flashing, cannot
Frigidaire Aquasurge dishwasher panel is flashing cannot clear flashing. Tried even turning off electric so it would reset. We only purchased it in August 2008 so it is only about a year and a half old.
  • 31 Answers
You might remove the front panel (screws on the sides) pop off the front plate, and remove the fuse. Put it back in after 5 minutes... sometime this fixes it
Posted on May 16, 2010
My frigidaire professional series aquasurge won't start
Good Afternoon Friend,
I understand your Frigidaire dishwasher, model# PLD3465REC, will not start. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire dishwasher shuts off mid cycle
Hello - From what you are describing it appears that the unit is attempting to run the cycle, but the wash motor is not coming on. Either the wash motor has failed or there isn't any or isn't enough power supplied to the wash motor. I personally recommend contacting a service provider to accurately diagnosis the dishwasher and to assist with the repairs.
Feb 22, 2013 | Frigidaire Gallery FGHD2433KW Fully...
Frigidaire dishwasher error code
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
Jan 19, 2013 | Frigidaire Dishwashers
I have the 4000 Series AquaSurge with speed clean Professional series. I have a white film on the dishwasher and all dishes, glasses and silverware. The right bottom of the door always has a leak about...
With regards to the white film, I would check for a soap buildup. Turn the dishwasher on, let it run for 5 minutes or so then open the door and see if there is suds. If there is, pour a half cup of cooking oil in the water and let it finish the cycle. That will clear the suds. It is possible that the rinse agent dispener has failed and is letting in too much jetdry as well. With regards to the leak, install a slash shield in the gasket, part number 154701001. it comes with instructions, really easy to put in and should fix teh problem.
Mar 26, 2010 | Frigidaire Dishwashers
I would suspect a faulty touchpad/console. They get moisture in them and short out causing all sorts of problems.
Mar 23, 2010 | Frigidaire Dishwashers
I own a frigidaire professional and the low light stays on what is wrong? Professional Series Aquasurge with Speedclean
the low light refers to the rince aid being empty. fill it back up and the light will turn off
Feb 05, 2010 | Frigidaire Dishwashers
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwashers Logo
599 people viewed this question
Top Dishwashers Experts
