Question about Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
Paper jam went try to sent a fax - Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
  • 734 Answers
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
How do i retrieve a fax from fax memory?
The reason why this happened?
1- out of papers
2- Out of ink
3- power on jam
try to solve all this issues without switching off the machine.
Mar 08, 2014 | Canon Pixma MX452
Machine reads document jam,checked machine seems ok,cannot sent fax.
Hi there!
The error message that you are getting means there's a jammed paper inside the machine particularly in the feeder. This may also appear if the panel is not closed securely. Try to open the control panel and look for any pieces of jammed paper or debris. Closed the front cover or the control panel, it should display the regular screen date/time. Once you have the regular screen load the document on the feeder, the display should change and should ask you to enter the fax number.
Hope this helps!
Please rate if it worked, Thanks
Mar 30, 2011 | Office Equipment & Supplies
Reprinting faxes already sent
Sorry, but, no...facsimilie machines have memory, however this memory is reserved for error conditions only (ie; out of paper, out of toner, out of ink, paper jam,etc.......) Unfortunately, if all faxes that were sent, were able to be recovered, it would take over a terra bite (or Tb) hard disk drive to "remember" or save these documents.....If you need the same document(s)...I would suggest that you ask the person to fax it (them) back to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=337&modelid=10116
Try this site for guides and further assistance. Hope this helps.
Aug 07, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Jul 01, 2009 | Canon FAX-L900 Plain Paper Laser
Have a Brother Intellifax 770. Machine went completely dead
Probably fried. Sounds like more of a power surge than a paper jam.
Apr 07, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Samsung SF560 error message door open & jam, no toner.
I have put a new toner in and it says "[jam 1] or no cartridge" please help this is an office fax and desperately needs to be working.
Many thanks,
Adrian.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
Rec . paper jam
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
Dec 13, 2007 | Canon FAX-L350 Plain Paper Laser
PAPER JAMMED
You have a stuck sensor.
Open the rear door and make sure there is no paper in there.
Remove your toner from the drum and make sure there are no bits of paper stuck under the toner cartridge.
l
Look inside the drum chamber for the little plastic levers that actuate the sensors. Make sure they move back and fourth freely.
Dec 05, 2007 | Brother IntelliFAX 4100 Laser Fax
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Jammed document
JC
I had the same problem- jam error with no paper in it. I tried all of the suggestions to no avail. So as a last resort before I went and purchased another one I unplugged it, picked it up, turned it upside down and whacked it a few times. To my surprise when I plugged it back up it worked just fine! Haven"t had any problem since. I don"t reccomend this but as a last resort, what the heck!
Jan 30, 2007 | HP 1040 Plain Paper Inkjet Fax
Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Logo
112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
