Question about HP OfficeJet 4255 All-In-One InkJet Printer
My printer shows remove and check your left cartridge
    President:
  • 1,138 Answers
Try this.. might help...remove the left catridge....turn off the printer... then using a cloth or cotton lightly moistened with alcohol or water, clean the surface of electrical contacts of the catridge(do not try to touch the contacts with your finger)... then return it back carefully...turn on the printer and try to print. If that didn't work.. suggest you replace the left catridge with new one... if you are refilling ink try to avoid touching the electrical contacts.
Posted on May 15, 2010
Hp 7280 all in one. Magenta ink (all new) does not work. Test print shows good cartridges and plenty of ink.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Jan 18, 2011 | HP Photosmart C7280 Printer
Bought new ink and not all the colors are printing black ink works good but colors red and yellow not showing up
To reattach the cartridge check the following steps :
Nov 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Dell 942 AIO printer and though I have replaced both ink cartridges, the printer shows "Cartridge Missing - install black or colour cartridge on left hand side"
Have you removed the shipping tape on the print head of each cartridge? Is each cartridge locked in each of their housing? Try reinserting the cartridges. Turn the printer off then on again.
Nov 08, 2010 | Office Equipment & Supplies
I installed new ink and printer shows clear paper jam does not appear to have paper jam
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
Oct 22, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Black cartridge problem
Try the steps mentioned in the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01091133&cc=us&lc=en&dlc=en&product=1141647
If it still does the same then the printer is not detecting the ink catridge, the printer might have to be replaced.
Good Luck
Sep 01, 2008 | HP PhotoSmart C4180 All-in-One Color...
Checked print cartridge but still flashing error
I am assumming both new cartridge seal tapes have been removed. I know it sounds like I'm being rediculous but you'd be amazed how may we get into the shop each week that this is the problem. :)
There is a known issue in this model and similar printers that causes a lot of them to fail. A spring tension wire that holds the cartridge in place in the cartridge housing breaks out of its clips where it hinges. If left unchecked it causes the wire to move back and puncture the flex cable that makes contact with the cartridge. There's a photo below that shows the wire broken loose and a photo that shows the resulting damage when left unchecked. If this is the issue, unfortunately the printer is not repairable as the parts aren't sold by HP.
Hope this helps you. If not conntact me back and I'll try and walk you through a couple other things to check.
Aug 05, 2008 | HP Office Equipment & Supplies
Only one colour showing at time of print
Maybe the ink well nozzle area has some dried ink left from the old cartridge. Remove the new cartridge carefully, and using a wet Q-tip,clean the area. Replace back the new black cartridge.
This worked for me ....good luck !
Sep 29, 2006 | Epson Stylus C64 InkJet Printer
HP OfficeJet 4255 All-In-One InkJet Printer Logo
129 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
