Question about IBM 15 Bays ProFibre Storage Array DF4000R Fibre Channel Drive Case
Accessing ibm df4000r array
We bought a used df4000r array storage and we have a problem with connecting to it.how can we find out the ip address of the storage or reset it? Generally we don't have any idea how to get access to this storage..
  • 5 Answers
SOURCE: Problem with new array.
Do you see your new disk in the "Disk Management" window? To get there go to "run", type "compmgmt.msc", then click disk management. If you do see the disks there, then you need to format the disk to a "basic" configuration. If your new disk/volume does not show up there, I would suggest a hard reset on your server whenever possible. I see this issue at times with Windows and newly added storage array logical drives.
Posted on Aug 31, 2007
Teh_shivers
  • 104 Answers
SOURCE: Home router won't exchange IP to set up wireless on laptop??
try resetting the router to factory settings, it may have been set to allow only 2 or 3 wireless connections, just take a pen and hold it in the reset hole on the back of the router till all the lights blink and it restarts
Posted on Dec 11, 2008
Muggs01
  • 72 Answers
SOURCE: Just moved IBM 6400 dot matrix. Need new IP address.
it should have kept the same address
Posted on Jan 19, 2009
  • 20 Answers
SOURCE: i bought a used ibm thinkpad t42 and can't access net
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jodiki39
Posted on Jan 03, 2010
SOURCE: I need to add IBM
If you know ip address of printer then you can access your printer with web interface for that type your printer ip address in internet explorer address bar.
then you can access configuration of printer.
But if you don't know ip then you need to check network configuration menu of printer .
For that press menu button of printer then enter in network settings then you can know the printer ip address.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 20, 2010
I have IBM eServer with ServeRaid-7K on board controller and have 3 SCSI 73GB hard drives configured in RAID-5 array. Hard Drives are running critically low on space and I bought 3 300GB scsi Ultra320 hard...
First, buy an external storage device, at least 80GB (although it's currently difficult to find any _smaller_ size!) and make a file-by-file, folder-by-folder, backup of your 73GB of "data".
Second, buy another external storage device, and do a Google-search for "drive image freeware".
Pick one of those applications, and do a "image" backup to this second external storage device.
Third, disconnect the 3 "old" drives, carefully label them, and set them aside.
Fourth, connect the 3 "new" drives, delete the old RAID-5 array definition,
and create a new RAID-5 array definition.
Fifth, do an "image restore" from the second external storage device to the new array.
If you have any problems, all you need to do to "back-out" is to:
* disconnect the "new" drives
* reconnect the "old" drives
* delete the "new" array definition
* redefine the "old" array definition
and you're back to the "old" configuration.
Dec 07, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
I have a FIA POPNETSERVER 4600 with no Software or Docs HELP!!!
The IP-address probably is provided by a DHCP-server on your network. Login to that DHCP-server, and look at the list of "active" clients, i.e., computers that have obtained an IP-address from the DHCP-server. One of the IP-addresses should be allocated to your FIA box.
Rather than "flatten-and-rebuild", you probably should investigate new software and new hardware to replace it, *BEFORE* it "dies", forcing you into a "panic-repair" situation, i.e., you need a "BCP" (Business Continuation Plan) which proactively addresses the non-availability of your "unmanageable" server.
Apr 08, 2010 | FIA Storage Systems Group POPnetserver...
The EFG120 has lost all network addresses and the setup disc won't allow re-entry.
use arp to assign an ip address to the mac address of the device , then use the new ip address to access the web page . might help
Mar 05, 2010 | IBM Linksys EFG120 EtherFast Network...
We forget the ip address for the MGMT port, we changed the default one
use arp .
find the mac address and then use arp to assign an ip address to the mac address . the you can enter the web front end using the ip address you assigned to the routers mac address and then find out or change your ip address. might not be any use to you
Mar 03, 2010 | IBM System Storage DS3400 Dual Controller...
Hi I'm using a DNS 323 and I had installed a Squeezeserver on it. At first this morning the web page from squeezserver wasn't available so I decided to make a roll back to factory default and recover the...
Since you rolled back to factory default then all of your configuration should be gone. You should still be able to connect to it using the DHCP address assigned to it though. Do the following to try to connect to it again:
o the following:
1. Try to ping the device using a PC connected to the same network.
2. If you are using DHCP, your device may just have been assigned a different IP. Try to ping all devices in your network or use a network scanner (e.g. SoftPerfect) to find out the IP address given to it.
3. Once you get the IP address, assign a static IP address to your device that is beyond the DHCP scope. This will ensure that your IP does not change and you will not have a conflict with DHCP assigned IP's.
Sep 18, 2009 | D-Link DNS-323 (DNS323) Hard Drive Array
Can`t acsess the DNS-313
Make sure the device is connected to your network then try this:
Jun 22, 2009 | D-Link DNS-323 (DNS323) Hard Drive Array
Can not access Dlink DNS313
When you said you tried resetting, did you mean you clicked on the reset button inside the hardware or did you mean you just rebooted?
* If you clicked on the rest buttion, then you need to configure again from scratch. Not sure if your data will still be available though.
* If you just rebooted, then the problem may lie in your LAN configuration. Do the following:
Dec 29, 2008 | D-Link DNS-323 (DNS323) Hard Drive Array
Infoprint 1570 MFP (RICOH)
try accessing the machines web page( browser --address= ip address )
Jun 24, 2008 | IBM Infoprint 1570 Laser Printer
Not able to access from linux
just restart the server ,it will again connected.
Jan 10, 2008 | IBM DS4300 (25r0168) Hard Drive Array
Aug 31, 2007 | IBM Total Storage DS400 (13n1777) Fibre...
IBM 15 Bays ProFibre Storage Array DF4000R Fibre Channel Drive Case Logo
78 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
