Question about Norcent Technologies PT-4235 42 in. EDTV-Ready Plasma Television
Norcent Plasma PT-4235 - Problem: black screen. When I press the power button, the green light comes on, but the screen stays black. Not even a flicker. Just happened one day, no warning signs. Any ideas?
  • 1 more comment
  • ayasta Oct 05, 2008
    We have the same problem with a PM-4201. It's less than three years old and suddenly has a black screen, but the power button is green so it is getting power.
  • norcent_fob Nov 16, 2008
    I have the same problem. The audio works fine but there is no video, just black screen. It happened just all of a sudden.
  • Anonymous Dec 08, 2008
    same problem
I have the exact same problem with mine last night did you find out what happened
Posted on Jun 11, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
My Norcent LCD TV LT2722 Turns on, but whenever you press a button on the remote or TV, it shuts off.
Green "ON" lights comes on (after some jiggling of the on/off button). Nothing else. Black screen, no sound. Where should I go next?
Aug 27, 2011 | Norcent Technologies LT-2722 27 in. LCD...
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
My plasma tv powers down
hello, Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement. Hope this will help
Jun 02, 2010 | Norcent Technologies PT-4240HD 42 in....
Norcent plasma PT-4235 - Problema: pantalla en negro. When I press the power button, the green light comes on, but the screen stays black. Cuando presiono el botã³n de encendido, la luz verde se...
ok here is one question... can hear the windows log-in sound?. If you do what you have to do is have someone or if you can do it, open the laptop and check the cable (flex) that connects the monitor to the motherboard (you have to disassemble) most of the computer or at least the top if you check the cable and is properly connected and still can not see a thing but you can hear windows then the problem is with your video card for that there is two ways to fix it the cheap (not the best) they have to heat the card up with a heat gun (that fixes it for a few weeks) or the other that may cost you a little more (maybe 250??) not sure.
take it to a repair shop and ask if they have a rework station (after they confirm the video card is bad) ask if they can replace the video card ---and don't take it to a big store they won't fix it--- they can unsolder it and install a new one. that is kind of common in some HP laptops.
lo siento hermano espero te sirva mi ayuda if it works don't forget to rate me
thx
May 25, 2010 | Acer Aspire 9810-6829 Notebook
Norcent plasma had smell of electrical burning and
get real bright flashlight shin close to the screen in dark roomand try to push the menu button if its the bulb you'll see some picture with flash light shining that shows your backlight is out
Feb 15, 2010 | Norcent Technologies PT-4291HD 42 in....
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
Norcent PT4291HD Plasma TV, no picture
The power will not stays on, it keeps turning off by itself
Dec 01, 2008 | Norcent Technologies PT-4291HD 42 in....
Picture stays on black
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 03, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Norcent Technologies PT-4235 42 in. EDTV-Ready Plasma Television Logo
377 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
