Question about Insignia IS 20" TV040919 TV
Screen is black except for thin line in middle of screen
My insignis is-tv040919 is about two years old. I turned it on today and there is a thin line in the middle of the screen that is obviously the picture and the rest is black.
  • 1 more comment
  • yolandaj1130 Mar 30, 2008
    I purchased the tv last year on 4-4-07 it was working perfectly until
    six months later. I turned the tv on to watch it and it just went out
    so i turned it on and off several times and it came back on. Then i was
    fine for several days and then it would do the same exact thing, but
    this time it would not come on for weeks at a time. I unplugged it when
    it would rain and when i would be away for long periods of time. Just
    like the manufacters booklet stated and still nothing so i ended up
    taken it back to bestbuy and it worked perfectly. But i got it home and
    the same thing happened. What is wrong with it? Is it a piece of junk
    or what? Mind you the picture show perfect when i can see it. Help
  • Elaine Hughes Jones
    Elaine Hughes Jones Apr 01, 2008
    ilo or llo 27" tv with same problem line runs across
    ilo llo tv 27" has line horizonal tv less than 1 yr
The veritcal ic is shorted out, replace the ic and check filter in the surrounding area. There is also a diode directly behind the vertical ic that has shown to give problems as well.
Posted on Oct 09, 2008
  • 149 Answers
Is that a flat screen LCD ?
Posted on Apr 01, 2008
I turned my television on then it made the tv frame made a noise!and now the screen is black except for this thin line across the middle of the screen which is display the picture
Most likely the vertical oscillator circuit has failed. As CRT televisions have gone the way of the dinosaur, my advice to you is to give a fond adieu and invest in a new TV.
Nov 05, 2015 | Televison & Video
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Started with one thin horizontal black line, then 3 shades over screen, now only static picture
Check and replace its back light CCFL lamps. If these are faulty, this kind of fault can occur. When replace it, replace all. None one or two. If you wish to get more details about the back light CCFL lamps and its working, check this link. Pull up older posts there.http://electronicshelponline.blogspot.com/
May 28, 2013 | LG Televison & Video
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
Apr 10, 2009 | Mitsubishi CS-27205 TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Insignia IS 20" TV040919 TV Logo
238 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
