Question about Coleman 5040-751 BackHome Open Flame Patio Heater
Pilot turns on but when I switch to turn it on,
Pilot turns on but when I switch to turn it on pilot flame goes off. Any suggestion?
  • easternheat May 15, 2010
    Are you sure your turning gas valve knob the right way most will be clockwise from pilot igniting position
  • 494 Answers
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
Posted on May 15, 2010
4 Suggested Answers
  • 53 Answers
SOURCE: pilot light goes out after when unit turns off
had same problem; its in the gas valve assembly
Posted on May 16, 2010
namizhka
  • 148 Answers
SOURCE: natural gas patio heater
MAY I KNOW THE EXACT MODEL # OF YOUR UNIT.
Posted on Sep 27, 2008
Therinnaiguy
  • 1420 Answers
Either you have a weak gas valve that will have to be changed or thir may be a partial blockage in the vent system or crack in heat exchanger. Does the flame change when the blower comes on? If so, crack! Check the venting system to make sure it is getting good fresh air and no exhaust is being sucked back in.
Posted on Mar 25, 2010
Why doesn't old Sears Gas heater turn on consistently?
If the pilot light is too small a flame, or the thermocouple sensor is too far away, it won't light. I suggest you find the small screw that adjusts the pilot light flame size, and increase it slightly. Quarter turn CCW.
Jan 15, 2016 | Heating & Cooling
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
At 300F after half hour, pilot and main gas burner was going off. When re-lit would stay on only 5 minutes thereafter. Had the thermopile changed(bought locally- not original from Imperial but identical),...
Hi there.
The thermostat will only shut down burner flame but not pilot flame.
Try tightening all wiring connections.
By using an ohm meter, check the continuity across the hi limit terminals when the pilot goes off, your hi limit may be tripping prematurely causing pilot flame to shut down.
Regards.
Jul 29, 2011 | Kitchen Appliances - Others
Pilot light goes out when gas turned on
I am assuming that you are saying that after you have pushed the pilot knob down and the pilot lites and stay lite and then you turn the knob to turn it to ON the pilot goes out...... Then the Gas Valve is bad and will have to be replaced....... Or if you are saying that the pilot goes out when the burners come on then you may need to replace the Thermocouple because the main burner flame is pulling the pilot flame off of the thermocouple and it is weak and will shut the gas off.... Or You could have a cracked heat exchanger that when the burners are on and then the blower comes ON and is blowing the flame around and blowing the pilot flame off of the thernocouple......which will shut the gas off....and then you will need a new furnace or New Heat Exchanger...... These are the most common problems Hope this helps.....
Feb 16, 2011 | Heating & Cooling
The pilot light goes out. When I go to re-light the pilot and turn the temp for vacation to medium the flame goes out again.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Nov 26, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
GAS FLOW IS TO HIGH PILOT GOES OUT EXCESS GAS FLAME ON TAPPEN FU
Hi this could be a gas leak on the pilot i would get this checked out
Mar 17, 2009 | Tappan TGF320 Gas Kitchen Range
Natural gas patio heater
Sep 27, 2008 | Heating & Cooling
make sure there is no dust dirt spider webs in the pilot hood if u have a nice blue flame coming from the pilot and u held the pilot knob down for at least 30 sec
and it still doesn't work then u have a bad THERMOCOUPLE
Sep 25, 2008 | Heating & Cooling
Pilot goes out
If the pilot won't stay lit, the thermocouple may be loose or faulty, the pilot orifice may be clogged, or the pilot light's flame may be set too low and needs to be adjusted. You can clear a clogged orifice with a piece of thin wire, such as a bread tie with the paper stripped off of it. Be sure to turn off the gas to the furnace first! Also shut off the switch or circuit breaker that controls power to the furnace. Just poke the thin wire into the tiny orifice where the pilot flame normally burns to knock off any ash or debris. Some pilots have a flame adjustment screw for adjusting the flame. To adjust this, refer to your owner's manual. Normally, this is simply a matter of turning the flame adjustment screw to achieve a full, steady 1 1/2-inch to 2-inch flame that doesn't have any yellow in it.
Jan 18, 2006 | Coleman 2 Burner Compact Gas 425F499G...
Coleman 5040-751 BackHome Open Flame Patio Heater Logo
716 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
