Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
A
Anonymous Posted on May 13, 2010
I cant connect to the internet and the green light has turned off
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on May 16, 2010
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
27186
Points
280
Hi
un install your old software then frist run disk when it ask to conact your adeptor then only conact it will detact aoutomatikly
Toshiba satellite 5005 s507 no wireless?
Use network to setup a wireless connection. You must have a RJ45 hard line for internet to perform this task.
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
I have 4 green lights and one red light on my router and I cant connect to the internet. How can I get 5 green lights and be able to connect to the internet??? P.s Iam using a wired connection at the...
While the router is connected to your computer try and switch it off and on.
From the Control Panel select Network and Sharing Center then Troubleshoot Problems and follow any requests to update drivers or reset the Network Adapter.
Can't connect to network and internet
It might be due to bad data cable connecting both XBOX and Modem try to Change it
1helpful
2answers
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
2helpful
The internet cable port cant dettect connectivity
Check your DNS settings after replacing the LAN chord....sodeep
I CAN NOT CONNECT TO THE INTERNET ..using Linksy wireless remote
the wireless card installed to your computer is working..as you said you can view all wireless networks...your computer is good too...the only issue is you cant connect to the wireless router...
turn off and unplug the power cable of the Modem
turn off and unplug the power cable the router
wait for 30 seconds
plug in and turn on the modem, wait for all the light turn to solid green ( no blinking lights )
then power on the router
if you saw the wireless icon light turn solid...
go to your computer...right click the wireless icon...select repair
if this doesnt work....reset your internet router by press and hold the reset button behind the router near the power plug (atleast 15 sec)
then connect your PC..the wireless network dont have the WEP key anymore because of the reset..you can reconfigure and put back the WEP key when you get connected.
Wireless is connected,but no internet
hey dear,
thanks for your time.... now, as i understand you correctly.. even though you seem to be connected ot the internet wirelessly, you are not able to pull out webpages right?
Try to power cycle the modem.. turn off modem and the computer for about 5 minutes... then try to power it on.. wait for the lights on the modem to turn green and then try to connect... you should be connected. good luck
Got forget to rate me....... take care.
red light means moden is out of sync with the isp. Power cycle. by unpluging the power from the back of yoru modem, unplug Your router and also turn off your computer. Turn on your modem frist wait until all lights are green>If they dont turn green. CHeck your cables. make sure telephone line is plugged into it or cable line. . There should be a cable pluged in from your modem to your wan port. Then from your router to your computer. Is this a wired or wireless connection. If its a wireless connection i need to know what what os your using. so i can help you set it up.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
