Question about Emerson EWL20D6 Television
Emerson 20" flat panel tv/dvd
While watching tv, the tv turned itself off. When I try to turn it back on, it will stay on for about 10 secs and turn itself back off. Normally when you hit the eject button, whether the tv is on or off, the dvd will simply come out. Now when I hit the eject button, nothing happens. SO now a dvd is also stuck inside the player.
  • 16 Answers
The problem is a bad inverter transformer replace the bad one and the set and dvd will work fine.
Posted on Oct 09, 2008
SOURCE:
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
How to correct the problem with my Emerson TV
Main system control memory IC fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 01, 2015 | Emerson Televison & Video
Emerson schematics tv clc320
Main board fault. Shorted component/s at it.
Aug 16, 2014 | Emerson LC320EM8 32 in. LCD TV
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
Emerson 32in flat panel has a resolution mismatch with my ps3
I had the same prob,first thing u need to do is to hold on ps3 power button for 4-6 sec until the ps3 resets and turns off.Next unplug and replug yr hdmi/red white and yellow wires in.Then turn ps3 back on it should adjust in 8seconds.
Sep 07, 2010 | Emerson LC320EM8 32 in. LCD TV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
37PF5320/10
Hello, I would advise as I do not know all the specifics to try to give the T.V. a signal from a cable box or dvd player. Then I would unplug the T.V. for about 5 minutes and then plug it back in and try to turn it on. Most newer televisions will have a One Year warranty included at the time of purchase so if all else fails, you maybe able to get a warranty replacement.
Jun 02, 2009 | Philips 32PF7320A 32 in. LCD Television
Prolbem
how old is tv?? and the best way to see if its the power botton is to try and hold for a few seconds and if it don't stay powered on then unplug and replug .....other then that sounds like power supply
Apr 01, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
NEW EMERSON 20" LCD STERO TV/DVD- NOT WORKING
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
Mar 10, 2008 | Emerson EWL20D6 Television
Emerson EWL20D6 Television Logo
270 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
