Question about Motorola Mobility RAZR V3i Cellular Phone
I need to clean my numbers board. How do I access
I need to clean my numbers board. How do I access it.
  • Motorola Mob... Master
  • 641 Answers
Im not to clear on what you mean by numbers board,so im taking a shot in the dark here.
#1 if you mean call history,you go to the menu ,select recent calls or call history,then go to the option for received calls,or dialed calls or all calls witch ever it is you wish to clear,then you'll see the option to delete calls.
#2 If you are talking about your contact list or phone book,You can delete numbers 1 at a time by clicking on your phone book going to the desired number ,then clicking delete,,or you can delete all contacts at once by doing the same thing only clicking delete multipul or delete all,if you use that option you have to knkow the phone security code.if you do not know it try the Motorola factory setting 000000.
hope this helps
Posted on May 15, 2010
Accessing the functions above numbers keys?
hold down shift key it will be near left bottom corner of key board. While you press 7 key. there may be another shift key on the bottom right hand corner of key board.
Jun 08, 2016 | Office Equipment & Supplies
My fan in my lower oven squeeks on start up can that be cleaned or does it need to be replaced
I appreciate your post, friend!
Based off the information you have provided the fan inside the lower half of your Electrolux oven is squeaking and you would like to know how to fix it. Typically, if your fan can be cleaned of any grease or dirt and in order to clean it you would need to access it. To provide you better information I would need to have your model number. You can locate your serial tag (which lists your model number) on the frame of your oven. With that information I can check to see how to access your fan. I look forward to helping you further. -Matt
Feb 23, 2015 | Electrolux Ovens
How to repair keypad some number not working bn59 00898a samsung remote control
If someone dropped coffee or soda pop in the remote, it sometimes helps when you open it an clean the space between the rubber pads, and the printed circuit board.
Don't use any aggressive fluid or scrub, because the rubber points under the numbers, do have a conducting layer. You need the conducting layer.
If it is soda pop you can clean it with clean water, and then just let dry. If the printed circuit board is damaged, or the conducting layer is gone, you wont be able to revive the numbers.
You then start saving for a new remote.
Jul 21, 2014 | Samsung Televison & Video
Main control board
Kenmore model number looks like this 795.51313012 90364894-0494-4d01-a2bd-9abc6a90a2c6.jpg
I am here should you need me, Thanks John Tripp Appliance 911
Apr 23, 2014 | Kenmore Refrigerators
I lightly sprayed my remote with Lysol to sanitize (everyone in the house has colds) and now it won't work at all. Any suggestions?
It sounds that the the sprayed liquid have been entered into its internal circuit board, due to pressure of spray. If so, you have to clean the internal circuit board. You can use, absolute alcohol, or, medical quality turpentine, to clean these boards. But, to access the board, you have to open the remote control. If you wish to get more details about how to clean and check a remote cotnrol, check this link. Hopes it will help you. Good luck.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 25, 2013 | Rti Technologies Televison & Video
FL GE Adora Washer - WHDVH626FWW, will not spin, clothes come out wet. When I run "rinse and spin", water comes in, but drum only spins initially left half turn, then right half turn, never spins...
Hi Walter:
In oreder your diagnostic, that means that your motor control board has faild and needs to be replaced. This part is located behind the lower front panel. if you remove the screws along the bottom of the lower front panel, you can then pull the panel off and the control board is on the left side with all the wires going into it.
You can replace it yourself if you'd like, you will need to remove the lower front panel to gain access which is probably the hardest part. And you can order the part from Repairclinic.com if you have a full model number if you wanted to.
You need the motor control board. Here is a link to the part for your model number: PartDetail/Control-Board/WH12X10418/1475761
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 11, 2011 | GE WSXH208A Front Load Washer
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
Need driver for assus mother board for lan connection to broadband server internet. because could not access to the internet by using broadband modem connected to lan at pc
> ASUS motherboard
What model-number?
Have you accessed the ASUS web-site, entered your model-number, and done a search for downloadable device-drivers ?
Dec 10, 2010 | ASUS Computers & Internet
I am trying to access the message board of web site. the error message is sql erro (msyq14)Too many connections [1040] An sql error occurred while fetching this page. Please contact an administrator if...
This is not something you can fix. The mySQL Server is only set up to deliver so many connections for the number of users X the number of objects needed. Several weeks ago the db staff must have added new objects to the system, exceeding the number of available connections. You need to let the website technical staff know this is happening. They did not test their changes adequately.
Jul 10, 2009 | Microsoft Press Internet Explorer 6
Kitchenaid start button wont work
I am having the exact same problem with ours. I decided to take it apart and have a look. After unscrewing all the stainless torx bit screws on the inside of the unit you can access the control panel. Underneath the buttons on the unit there is a circuit board with the switches mounted to it. The start switch on the board is corroded. I tried cleaning it but it did not help. On the board there is a part number stamped 8530995. I have found the board online for $47 and I've ordered it. The board pops out and has a connector attached to plug it in. To access the board you'll need a set of torx bits and a flat head screwdriver.
Jan 29, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Motorola Mobility RAZR V3i Cellular Phone Logo
194 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
