Question about KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range
The Knob for the oven temperature broke off KITCHEN AID DUAL FUEL
The Knob for the oven temperatur broke off The plastic stem piece is very thin and broke It is the right knob centre of right controlling the oven temperature It has no markings on the black know model # KDRP467KSSO Serial XP0408190 would I be able to disconncet and reconnect all the wires and the board behind the knob myself? Do I require an appliance repair man? Thnaks Danny
fridgetech
  • 473 Answers
SOURCE: Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Posted on Oct 18, 2007
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
espressonist
  • 1711 Answers
SOURCE: Kitchen aid superba oven is
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Posted on Oct 02, 2010
TheMobilian
  • 8220 Answers
SOURCE: My Kitchen Aid Superba oven will not heat up. As
That sounds like a bad oven sensor. I would check that sensor for short or open.themobilian_850.jpgthemobilian_851.jpgthemobilian_852.jpg
Error codes and service manuals posted HERE
Posted on Jan 12, 2011
Do I really need to replace the whole oven thermostat on my Viking if only the knob shaft broke off?
I would follow his recommendation. If it is not repaired correctly you will have temperature problems and it will hold the know in the right position.
Apr 29, 2014 | Viking VGSC306-4B Gas Kitchen Range
Thermador dual fuel oven temperature not accurate and the dials dont match temperature
Faulty thermostat it's the thin copper shaft in the oven that has a skinny tube running from it if you remove the oven knob you will find it goes back to the switch. Needs replacing.
Apr 21, 2014 | Thermador P304CS Gas Kitchen Range
WFE371LVB0 whirlpool stove oven temperature changes
Sounds like your thermostat has perished, it's the long skinny tube in the oven with a thin copper pipe leaving it, pull off the oven knob and the thin tube goes into the back of the oven control, replace it!
Apr 08, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Aid dual fuel oven, getting an error message F 02
F2
Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this
happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN
models: check door lock operation.
3. Look for a high resistance connection
or any other cause of high resistance in the oven temperature sensor circuit.
Check sensor, sensor harness and sensor harness connection at sensor and oven
control. Replace sensor if found defective.
Remember: Oven control
(ERC) measures resistance of sensor circuit, not actual oven
temperature.
Jan 02, 2011 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Uneven oven temperature
It is possible that the thermostat on your oven needs calibration. However, major errors in temperature may be the result of a bad heating element or a door that doesn't close or seal properly, etc. Confirm that the oven is in otherwise good operating condition before attempting calibration.
Most thermostats have a calibration screw located under the knob. Try pulling the knob off and look at the shaft. Some shafts have a small screw located in the center. Rotating this screw will change the trip point at which the thermostat will turn on and off. This is determined by the sensor located inside the oven itself. Some other schemes allow for the entire control to rotate with respect to the scale. You will need to identify the type used on your oven.
Let me know if this helps.
John
May 07, 2009 | Kitchen Ranges
I cant get my viking 30inch electric range to self clean. it has a self clean spot on the knob and on the temperature knob but when both in place nothing happens.
You might need to lock the oven door to get the self clean to go on. My stove had a lever which locked the oven door when you pushed it sideways. It was in the middle above the oven door, in the gap... Hope this helps!
May 06, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
I have a feature on conv oven i dont understand what it is
It is probably a self cleaning oven. If you turn your knob to this your oven will clean itself. I hope this will help you.
Nov 23, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
GAS OVEN
This oven has an electric thermostat control and it is most likely shorted out or the contacts are melted shut......replace the control switch that temperature knob is on it has two wires going to the gas valve.
May 15, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range Logo
56 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
