Question about Pioneer PRO-530HDi 53" Rear Projection Television
Power problems with PRO-530HD
The picture looked like it was pushing up and back into the tv.  I just got the tv yesterday, so that was what the menu looked like.
    Champion:
  • 213 Answers
Need stk392-110 if that in it but i use stk392-120 you whant to ch restor by the ic stk392-110
Posted on Apr 01, 2008
NEED OPERATING MANUAL FOR PIONEER ELITE PRO 530 HD TV
both may be a little hard to find anymore, the main problem is dead set and that is bad soldering all over the giant power supply board this set uses.
Sep 02, 2012 | Pioneer PRO-530HD 53" Rear Projection...
What's your problem?Pioneer PRO-530HD 53 in. Rear Projection Television flashing red standby light
This and a few other models like it have one real common issue:
they develop from age and heat bad solder connections all over the power board (rather large board).
My experience with them is the fix usually is remove rear cover and follow power cord to power board (a lot of plugs to mark) and remove that board----then solder every single connection on the board which by the way has some special fuses on it.
Jun 14, 2012 | Pioneer PRO-530HD 53" Rear Projection...
I have multiple colors on the screen of my 530hd pioneer elite TV when it warms up. When I try to adjust the convergence I am unable to move the red line far enough to converge on the blue or green line.
The convergence of your tv is defective try to replace it. You will find the convergence chip inside your tv, try to open the back cover of your tv but be sure to unplug the tv first. Try to look the large aluminum plate it is the heat sink, your convergence chip is attached to that heat sink it has a marking of stk-*** followed by a number you should remove it from the pcb using a soldering iron, and soldering pump but be very careful you might damage the pcb and may caused another fault to your unit. Or you can contact a service technician to save you from stress. Good day and best regards.
Jul 19, 2011 | Pioneer PRO-530HD 53" Rear Projection...
Pioneer PRO 510HD - 53"
Boards can run 250 - 400.00 on average. You may be better off just repairing the board parts for around 65.00
See below
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Pioneer PRO-530HD 53" Rear Projection...
I have HD hooked up to my TV. As of yesterday,
Did you try to reset the picture settings in the menu? Do you have the same problem with other inputs or just the HDMI input?
Oct 16, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Jan 19, 2009 | Pioneer PRO-530HD 53" Rear Projection...
do you know what the pix look like be for it whent dead?
some time bad solder can do this. in the center of the board
thear is fuse that go bad because of bad solder on stk 392-120 or 110 on the conv. pcb the fuse is 5amp 125v you have about 3 of them on the def pcb. to ch them. to hit the flyback&hozoutput
ch cap.s in power supply.
Mar 30, 2008 | Pioneer PRO-530HDi 53" Rear Projection...
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Jul 01, 2007 | Toshiba 43AX60 43" Rear Projection...
Pioneer PRO-530HDi 53" Rear Projection Television Logo
77 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
