Question about Whirlpool Duet GHW9150P Front Load Washer
I cannot get the door to open now the cycle to start. I have pushed the rest button pause button unplgged it everything I have done beofre to get it to open and nothing happens
    President:
  • Whirlpool Master
  • 662 Answers
Washer shd be switched on. Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Posted on May 19, 2010
  • prem mathew May 22, 2010
    If you remove the small access panel on the bottom front of the washer there is
    a white plastic type cord that you can pull and this should also
    release the door. Release excess water thru drain hose in front before
    you open washer door, after all the water drained remove the drain pump
    cover, clear the junk and look to see if there is anything obstructing the pump;there
    will some water which will normally drip out here so keep plastic bags
    ready. Refit.
Why is my washer displaying a "DR" when I push start?
  • 1 Press any button on the display panel.
  • 2 Wait five seconds and then press and hold the "Start/Pause" button and the "Cancel" button at the same time.
  • 3 Open and shut the door. A "DR" error code indicates that there is a problem with the door, most likely that it has not shut properly. Check to make sure there are no clothes or other items caught in the door.
  • 4 Open the door and gently wiggle the door latch if the door does not click shut. Clean it with a damp cloth to remove excess dirt or debris that may prevent the door from latching into position.
  • 5 Close the door and re-select a new wash cycle and "Start."
  • Jul 25, 2014 | Frigidaire Affinity ATF6000F Front Load...
    Bosch Nexxt 100 series washer wfmc1001uc
    According to the manual, you have to:
    1. Turn program selector to "off"
    2. Turn selector to Drain or Spin
    3. Press the start / pause
    Wait until program ends.
    Open door.
    or
    Press "start / pause" until the start / pause light flashes.
    Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
    I dont have a stop buttom
    You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
    Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
    Opening the door after a wash
    Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
    OR
    OR
    First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
    The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
    Pl click if helped.
    Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
    Why is F16 code flashing up on my bosch avantixx washer dryer
    The door is not locked properly.
    Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
    Aug 26, 2012 | Bosch Logixx WFT 2806 Front Load...
    My watch was accidentally put in the washing machine. The cycle had started before I realized it. I have tried to open the door however is locked and will not open. How can I get the door unlocked so I can...
    Pushing the pause / start button will unlock the door in all but the sanitary cycle. If in sanitary cycle, you may have to turn off power, then turn power back on.
    Mar 17, 2011 | LG Washing Machines
    Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
    Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
    Nov 07, 2009 | Washing Machines
    F-26 flashing
    DOOR SWITCH ERROR
    If the door has not been opened for 3 consecutive cycles or the door
    switch is open while the door is locked for more than
    5 seconds.
    Door not opened during 3 consecutive cycles.
    1. Open and close the door.
    2. Verify CCU operation by running a Diagnostic Test or any cycle.
    Door switch open while door is locked.
    1. Push the door and check if it is completely closed.
    Faulty door Switch or CCU board or door not closed during run cycle.
    Starting Diagnostic Test and bypassing
    the Service History Mode:
    Execute this procedure with an empty drum. All
    of the steps below must be done in sequence
    in order to reach the Diagnostic Test. This
    executes the automatic test but does not show
    the error history.
    Close the door.
    Push POWER.
    Select the CLEAN WASHER cycle.
    Press EXTRA RINSE four times within
    5 seconds.
    Press EXTRA RINSE to advance to the
    next step of the test procedure.
    If the starting procedure fails, push
    PAUSE/CANCEL, then repeat the starting
    procedure.
    Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Can't get washer to start again after pushing pause/cancel button
    sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
    Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Pause mode stuck
    Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
    Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    65 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
