Question about Philips 50P8341 50" Rear Projection Television
Turns on but no picture or sound.
Phillips rear projection tv turn on but has no picture or sound.
I have checked three visible fuses and they check good.
  • doittoya Mar 30, 2008
    the led power indicator is lit and clicks when turned on but no power or sound. The power led goes out after about one minute.
  • Philips Master
  • 5,568 Answers
There are not many things that audio and video have in common and the power supply section is most likely at fault.
If the system has an LED indicator and it isn't lit, the supply is probably the reason.
This is not a good place for users to troubleshoot and can be dangerous, even after the power has been off for an hour or two.
Posted on Mar 30, 2008
  • Steve Allison
    Steve Allison Mar 30, 2008
    That the LED comes on until the whole set dies, suggests the supply has some outputs temporarily working.
    The fact that the set dies again could very well be a capacitor as 'early' suggested that has failed or lost value, a problem found often in inverter (switching) power supplies.
    This could be a 50 cent part but unless it has blown its case off or at least caused the case to bulge (visible at the top), locating this part requires some knowledge and a meter.
    I don't think the main power cord is at fault.
  • 871 Answers
Please check the connection wire/cable that gives power to your tv. if no fuses are blown. it may be a capacitor problem.
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Is anyone there? I am having a problem i have never run into before. I have a phillips rear projection 55" which is about 7 years old. All of a sudden the picture went out. I checked the fuse and it was...
You have a bad small signal module! Location should be in the rear left side. The board will require extensive work to pull out and reworked or replaced! This board will have three large heatsinks with convergence ICs and an audio ICs attached to them.Good Luck and thanks for asking!
May 24, 2010 | Televison & Video
Phillips Rear Projection No Picture
check power supply and fuses.
May 31, 2009 | Televison & Video
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Philips projection tv - on button blinks, but does not turn on.
does it have sound?
how many times does it blink?
have you checked for blown fuse?
Dec 11, 2007 | Philips 50P8341 50" Rear Projection...
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Toshiba 42H83 rear projection tv turns on but i have no picture or sound. happened suddenly. What can troubleshoot before seeking proffessional hel.
Check all micro-fuses in power supply.If two or three are bad,a convergence circuit O/H will be necessary.Pro help usually required-chassis pull,replace convergence IC's and careful hand- soldering needed to prevent call-back.
May 21, 2007 | Toshiba 42H83 42" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
