I have a dell dimension 5100. i have just recently replaced my hard drive and usb connectors due to one being shorted out. i had somone look at it and when it came back it worked just fine for a bit. Then it just reboots. Now when i say it just reboots sometimes it does not even get through the bios before it happens again. What could be the problem. Do i jus need to trash it or is it worth buying a new motherboard and cpu
    Champion:
  • 218 Answers
It seems like somthings shorting out the computer seems to me if its doing this the problem my be the psu (power spply unit) id if i were i would reset the bios too hoppe this helps
Posted on May 15, 2010
Dimension 5100 wont start up .power led on MB is on changed mb.shorted out test done fan went.nothing else.what next ???
I have seen more than a few of these (Dimension 5100 series) die due to mainboard issues. If you haven't done so already, take out everything you can, (add-in cards, modem, disconnect hard drives, CD drives, etc.) Try to restart. If you get it to boot, you can add in one item at a time, and realize that when it won't start that is probably the culprit.
Next, If you have a second PC that has known good RAM of the same type, I would swap that out as well. Then try to boot with just video, Mainboard and RAM. If you see any blinking lights/sounds/etc. then report that on here as well. There are beep codes and on Dell's there are light error codes.
I you do happen to have a spare CPU, you could swap that out as well if you can, but I would not bet that is the problem as they are pretty durable for the most part.
If none of these comes up with a booting PC, it could be your replacement mainboard is bad.
Mar 19, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
What is the maximum drive size I can install on my SATA controller?
Looks like at least 400Gb see below.
Product Details for 5100 400Gb Desktop SATA Hard Drive This SATA Hard Drive is used and has been tested for proper functionality.
Dell Dimension 5100 400Gb Desktop SATA Hard Drive.
Hope that helps.
Feb 25, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Slave drive into Dell Dimension 5100
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Jun 07, 2008 | Dell Dimension 4600 PC Desktop
Hard Drive Upgrade on Dell Dimention 5100 Desktop
are you replacing it, or simply adding one to your desktop?
best place to get that information is www.dell.com
click on accessories
Feb 27, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power Problem
Try removing the ram and place it back in, If that does not work your power supply has a short in it..Replace it
Dec 16, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 9100 PC Desktop problem
I'm not sure where the floppy drive comes in, but if you have usb connectors on your mobo then you can connect the 5 pin connector to half of the usb pins.  Try that and see what happens.
Oct 25, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
