Question about HP Photosmart C6180 All-In-One InkJet Printer
Cant get it from offline to print - HP Photosmart C6180 All-In-One InkJet Printer
    Scholar:
  • 42 Answers
You did not clear that the printer is connected in wireless or Usb. However, below are the steps for both.
USB.
Please click on Start on the computer----Control Panel----Printers or Printers and Faxes or Devices and Printers.
Please right click on C6180 printer icon and click on use printer on line.
This will fix the issue, still persists, follow the below steps.
Click on Start- and in the search box type "services.msc" and hit enter.
Here, do we see an option print spooler?
Just stop that print spooler
and then restart that spooler.
WIRELESS.
Press the Setup button (cant get it from offline to print - c01461502.gif ) on the front of the printer.
Press the Down Arrow button (c00718778.gif ) to highlight Network , and then press OK .
Press the Down Arrow cant get it from offline to print - c00718778.gifsrc="http://i.fixya.net/uploads/images/c00718778.gif" alt="c00718778.gif" class="h_mi" /> ) to highlight View Network Settings , and then press OK ) to highlight Print Network Configuration Page , and then press OK .
Please note down the ip address of the printer and then follow the below steps.
Right-click on the printer Photosmart C6180 series---- click " Properties" , and then click the Ports tab
Click Add Port .
Click TCP/IP port and put (ip address of the printer)
, and then click New Port . The Add Port wizard starts.
Click Next ,
Follow the on-screen instructions to finish adding the port.
Then try to print and the issue will be fixed.
this isuue occurs because of the power failure or thunder storms or if we turn the router OFF.
I would suggest you to never turn off the router.
If, however, you face the same issue with the printer, please follow the same steps and the issue will be fixed.
Posted on May 15, 2010
Cp1525nw appears offline
If the system is unable to detect the printer, it will put the printer in offline mode. In this condition you won't get any print outs..
1. chk usb cable
2. un plug the usb cable, un install the drivers, plug the usb cable & chk new hard ware found?.. if not there is usb port issue, chk system usb port/s are working or not.. if yes
3. Replace printer formatter assmbly...
This printer network unable printer, why cant use through network? instead of replacing the formatter assembly...
Jan 02, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
MY LEXMARKX5650 THERE IS A DOCUMENT STUCK IN MY QUEUE. IT SAYS DELETING BUT IT DOESNT DELETE I CANT PRINT MY OTHER DOCUMENTS I REALLY DONT WANT TO HAVE TO RESTART THE PC IHAVE A FILLED IN DOCUMENT THAT...
Disconnect the printer from the computer. Open the print queue, and be sure that the title bar says "printer offline". If it doesn't, select "use printer offline" from the file menu. Then try to delete the file multiple times if necessary to clear the queue. You may have to reboot the computer, but try this first. Also, you can try pressing cancel on the printer itself. If none of this works, disconnect the printer from power for 10 minutes, and try again. Good luck!!
Sep 29, 2010 | Lexmark X4650 InkJet Printer
Change Printer Cable (USB or Parallel). Its show offline because its not getting connection to printer.
Re- Plug Cartridges also.
Mar 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
Lexmark1200 series printer not getting the message to print, does not say there is an error
Check that it is set to be the default printer. then check the aplication you are trying to print from that it has not set the printer to be offline. Sometimes IE or firefox ( I cant remember which) will say to print offline for some stupid reason.
Mar 09, 2010 | Lexmark X1270 All-In-One InkJet Printer
Photosmart c6180 printer status offline
IF you have more than one printer set up on your system take all the others off except this one if you are able to without disrupting your home printing flow for others.
Another suggestion would be to download the newest drivers if you have not already; I found the site below with the drivers for this printer at:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=1153494&
Hope this helps.
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cant print . says something about offline.
go toand open printer settings click the printer icon in that menu it should say use printer online highlight and click.
Good Luck
Jan 30, 2009 | HP PSC 1210v All-In-One InkJet Printer
I cant install the printer Hp deskjet 2460
what do you mean you have another PC or you just change the MONITOR??if you have the a new PC you need to install the software of the computer but if you did change monitor you can just go to the CONTROL PANEL>>PRINTERS and FAXES>>check if the HP Deskjet 2400 series is offline/ready.if its offline right click the icon then use printer online..
send feedback for more troubleshooting instruction
Sep 06, 2008 | HP Deskjet 2460 InkJet Printer
Printer offline
Go into control panel/ printers and faxes and see if you have more than one copy of the printer in there. (it may have installed more than once) make the last copy of the 780 the default printer then it should be ok.
Aug 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
185 people viewed this question
Seeker5211
Seeker5211
