Question about Technics SL-1210 Turntable
Technics 1210's playing out of one speaker / channel
Hello. I have a problem where both of my decks are only playing out of one channel/speaker. Mixer is new and cables seem to be working fine. Any ideas would be greatly appreciated
  • 32 Answers
I had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Posted on Jun 10, 2010
The grounding can be a problem. Try using any kind of wire (you can use RCA cables), or you can touch the tone arm yourself.
Posted on May 21, 2010
  • mare_cccp May 21, 2010
    1. The connection between your headshell and the tonarm - check it. The simplest way to do it, replace it with a headshell that works for sure.
    2. The grounding can be a problem.
    Listen if it's pure one channel mono, or can you hear a dull bass noise on the other? Now, use any wire to connect grounding on your mixer (or whatever, you can touch pretty much any big metal thing) with tonearm (metal surface). You can also touch it yourself, and produce stereo output.
    Whatever it is, the wiring for the technics 1210 tonearm is pretty simple, and separated from the rest of the turntable... but maybe you would like an "expert" fixing it for you...
    Worse case scenario is your wires inside the tonearm or the base of it are messed up... but it's not really that much of a problem.
  • Technics Master
  • 5,349 Answers
Have you considered the amp to be the problem? The amp has a magnetic cartridge pre-amp, which only the turntables would use, that can fail. It's often a single IC that has gone.
Posted on May 17, 2010
2 Suggested Answers
  • 32 Answers
SOURCE: Technics 1210's playing out of one speaker / channel
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Posted on Apr 18, 2010
Hi there, i just bought 2 Technics mkii
well" for a start, they need to go into a phono socket, this amplifies them.
i take it you bought 2 decks with the intentions of mixing, so you gonna need a mixer.
MIXER & DECKS SET UP:
1.decks into phono channels 1&2
2. black GROUND wires, go to GND screw on back of mixer
3. RCA master / booth Outputs on mixer to AUX / LINE-IN on amp.(not phono)
Oct 09, 2013 | Technics SL-1210 Turntable
One of my decks sound louder than the other
I'd say the cartridge is getting tired. Swap the head shells with carts and test. Cheers john. Styluscity
Nov 27, 2012 | Technics SL-1210 Turntable
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
Record only plays through one speaker
If it works on Channel One it is NOT the TT. It's a mixer problem. Define the mixer and what else works or doen't work. have you tried another device on Channel 2?
Apr 30, 2010 | Technics SL-1200MK2 Turntable
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Apr 18, 2010 | Technics SL-1200 Turntable
give them a shot
Mar 22, 2010 | Technics SL-1210 Turntable
1 X 1200Mk2deck higher volume / causing spkr not to work..
Problem If you swapped the two TT's would the problem stay with the connection on your mixer? At least then you/we would know wherein lies the problem. I'm betting thge low volume is because you have the phono jacked into a line level input like AUX instead of PHONO.
Typically, what you're describing is a phone source plugged into a NON-phono connection. (Tinny, low volume - classic lack of a phono preamplifier with RIAA equaliztion). A standard old-school tuntable requires a phono preamp that is labeled "PHONO". Nothing else will give it the boost and freq response correction LP's and phono cartridges produce.
Your problem #2 alludes to a channel problem with a turntable running through your mixer. This isn't rocket science. Swapping the two turntable channels around would probably change the apparent failing channel, right? Yes - Problem out at the turntable. No - problem in the mixer. You've already hinted at the source by monkeying with the tonearm wiring. You're on the right track. The tiny multi-colored wires in the cartridge shell are very thin and delicate. Their brass fittings sometimes oxidize and reseating them as you have done usually gives some relief. Kinks in the wires could cause your intermittent symptom. At the RCA end of the tonearm cables, make sure they're seated on with a twist to wipe off oxide.
Problem #3. Is it just bothering you or is there a functional problem, too?
Apr 21, 2009 | Technics SL-1210 Turntable
Pioneer djm 800 will only play through 2 channels on mono??
try to clean your fader with contact cleaner and move it many times after cleaning -check your connection plugs(buy it from radio shack near you.
Apr 11, 2009 | Audio Players & Recorders
Channels
Could be one of 3 issues:
1) Tonearm
2) RCA Cables
3) Cartridge/Styli
I generally tell people to try different cartridges first. If that doesn't work, then you know it's either your tonearm or your RCA cables. 80% of the time, it's the RCA cables. It's very hard to determine which one it is at this point without opening her up and putting on some new RCA cables to test. If it works, then your good. If not, then you know it's your tonearm, and will need to be replaced.
- DJPROLAB
Feb 13, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
260 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
