Question about Home
Toto toilet does not flush properly - insufficient water to make it flush properly - need to pour water down toilet for it to flush. There is not any kind of blockage.
  • 349 Answers
Check water level in tank for proper height it should be about 5/8 close to top of stand pipe in tank or it should have a mark on it wher it should be.
You can adjust the flush valve to increase water height.
Posted on May 16, 2010
My Toto toilet runs after a flush. If I turn the water supply off for a day or so it will stop running but will do it again after a couple of days
If your Toto toilet has some sort of flapper, it may not be seating properly or may be defective.
Jul 30, 2014 | Toto Home
Toto neorest 500 take two flushes to work properly
Water pressure may not be strong enough or the tank is not filling up well in the back.does it have trouble on just flushing urine.
Jan 13, 2013 | Toto - Toilet - One-piece - Neorest 500 -...
Toto Dorian toilet does not flush clean
Don't know if you have calcium build up problems. If you do you could pour a calcium cleaner into the tank to try and clear up the problem. This would be the only way to possibly clean the enclosed area. Good Luck. Jeff
Apr 05, 2010 | Toto Promenade, 1.6 GPF, Elongated...
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
When you flush, the bowl refills and then suddenly empties 90% of the refilled water. Why? This is a toto toilet and this happens almost all the time now.
it sounds like it is not flushing completely at first and then releases and the suction is pulling water out of the bowl. Could be a venting issue or a clog issue that is hindering the proper flushing of the toilet.
Nov 23, 2009 | Toto Home
Toto seems to flush,but suction not working and waste not emtying
check the discharge hole, meaning you have to take down the toilet.
and make sure the water in the tank is at a proper high. you need the volume to create the wirlpool and push the waste.
May 20, 2009 | Toto MS853113S#11 UltraMax Round Toilet,...
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
TOTO WASHLET LEAKS!
from where?? If it is leaking on to the floor from the base of the toilet you need a new wax ring installed,,, if the water is comming out from where the tank bolts to the bowl you need to get the proper kit since it;s a toto they are one of a kind and don't have any universal kits that will work, call or e-mail toto tell them you need the tank to bowl kit, might as well tell them to send the flush valve also and just do the whole thing good luck
Feb 20, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Our toto toilet wont flush the water down. We plunged it to no avail, then we ran drain clearing baloons it wouldnt clear out. we keep removing the water with plastic pots. So we can try something else....
Sounds like something is either in the bowl stuck or down in the waste line. I would probably pull the toilet and pour water down the waste line to see if it backs up or set the toilet up on something and pour water into the bowl to see if it comes out. At least it will help to find out where the problem is. Have you lost anything recently that might have fell in the toilet. Did something come off of the plunger and get stuck in the bowl?
Feb 19, 2009 | Toto Lloyd 1pc. E/F Toilet w/Maple Seat ...
Home Logo
486 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
