Question about Dishwashers
Whirlpool Built-in dishwasher Model DU8700XB -O
Whirlpool Built-in dishwasher Model DUB700XB - will no longer clean dishes leaving bad limescale residue / dirt on dishes . I have lost the manuel and do not know how to take it apart to clean it
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Whirlpool Built-in dishwasher Model DU8700XB -O
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
It's under the lower spray arm. Post your model number and I may can find a diagram for you. Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Posted on Mar 22, 2010
Dishwasher model Whirlpool gu2700xtsb1 does not seem to get dishes clean and leaves a significant amount of soap around the dispenser area. How do I fix that?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenanceDishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 12, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
It doesn't seem to clean the dishes very well it comes out with some kind of white coat like limescale or something
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 29, 2010 | Whirlpool Dishwashers
My dishwasher is leaving a white thick film on my dishes.
Check your inlet water quality. If hardness is noticed add salt as per the directions of the manufacturer. Refer user manual.
Check the rinse aid compartment and fill it with rinse aid as recommended by the manufacturer.
Apr 13, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Mar 22, 2010 | Dishwashers
Regular cycle no longer cleans well
Thanks for the clarification (we get a lot of people on here that don't know how to really use a dishwasher).
Sounds to me like the DW may need a through going over.
Confirm the make and model of the DW so I can see how it's built. I am suspect that with all the food particles and film you mention, that the spray heads are clogged in the spray bars, and, check that the drain hose is not kinked, and it's attachment into the garbage disposal is clear. I've had these clog before, limiting the ability of the DW to get rid of the dirty water.
Dec 17, 2009 | Whirlpool 24 in. DU930PWP Built-in...
Salty white dishes
Pour white vinegar into the rinse cycle, this should help.
Apr 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Our less than 1 year old Whirlpool dishwasher model DU1145XTPQA is taking as much as 2 and 3/4 hrs. to complete the entire dishwashing (normal)cycle. This is much longer than it used to take.
Contact Whirlpool service immediately to get a service call scheduled before the warranty expires.
Most dishwashers that begin taking longer to complete the cycle have a failed heating element but that also normally means that the dishes do not get fully clean and the glassware has a film on it after the cycle ends.
Good Luck!
Apr 07, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
My tablet won't dissolve.
Sounds to me like the dishwasher isn't filling up with cold water. I had a similar problem a few months ago, caused by limescale blocking the inlet and drain valves. Might be worth trying some kettle limescale cleaner solution and putting it inside the machine - and leaving it overnight then trying the machine out with no dishes etc in it.
May 16, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwashers Logo
146 people viewed this question
Top Dishwashers Experts
