Question about Ruud UBHC Air Conditioner
My furnace comes on and heates the house for about
My ruud Silhouette ii (UGPH-07EAUER) furnace comes on and heats the house for about 10 minutes. Then it shuts down normally and immediately restarts - no pause at all. This repeats for 2 or three times in the morning (when the house is cold) and then the furnace works normally (on a while off a while) for the rest of the day. Acts like some kind of temp limiter in the heat box shuts the furnace down and as soon as the burner goes out cools enough to let the thermostat restart the furnace???
    Problem Solver:
  • 18 Answers
There is a limit switch that is likely opening. Be sure your filters are clean and all registers and grilles are open and not obstructed. If the problem continues, you may have a dirty indoor coil or undersized duct work. Some models have a window where you can observe the LED lights. If when the furnace shuts down you see any blinking, you need to count the flashes and we can figure out what the problem is from there.
Posted on May 22, 2010
I have a Ruud Silhouette II plus LXE that the hsi is energizing when the thermostat is in the off position. We have not used the heat in months only the A/C.
If the inducer motor is not turning on, it is not getting a call for heat and the hsi should not be energized. If it is energized without a call for heat, then the circuit board will need to be replace in the furnace...it has stuck contacts on the hsi relay.
Jun 26, 2016 | Ruud Heating & Cooling
My Rudd Model# UGPH-07EAUER Silhouette II furnace goes into lock out. I have replaced the filter and still happens. I actually thought it might be the Limit Switch and replace all 3 of them. Still goes...
Does this unit also have an AC coil installed? Can you check to see if it is dirty or blocked? Although you are not cooling the heated air must still pass through this component. Has it ever been operated without a filter? How many return ducts tie into the unit and is each path filtered? Do you have filters in the individual return grilles? What do the blades on the blower look like? It sounds as if the temperature may be too high if you have to continually reset the high limit. This occurs when you have low air flow.
Dec 10, 2013 | Ruud UBHC Air Conditioner
Hello, I have a Ruud Silhouette II Plus 2 gas furnace installed in my garage. This is the first time that I've had a gas furnace (living on my own) so I am unsure of how it actually works. One thing...
If you have gas furnace, the outside unit will not come on unless you have dual fuel/ gas and heat pump. If you can look at wires in thermostat, if you have no wires going to O or B then you don't have heat pump. Normal tstat wiring for gas furnace and air conditioner. R,W,G,Y and maybe C.
Jan 24, 2011 | Heating & Cooling
Ruud gas Furnace UGPH 07EAUER cycles properly heats to temp and shuts down normally.....then a little while later it cycles, but does not ignite. Blower circulates cold air through the house negatiing the...
Whew...
Most likely... Your part number (look it up)
RUUD 47-25349-?? (LIKE: 02, 03, 07... etc).
(typically: $10 -$20 range... easy job)
On eBay:
A bit slow getting this answer out on the table...
Sorry anonymous.
BUT for the "over-temp" condition...
Forget the wall THERMOSTAT.
There's usually a switch to option the "DEPTH" of
your heating cycle
(Look up Owners GUIDE for your SPECIFIC MODEL).
The "cool down"... (if there is one) would more
likely be you heaters OWN (fan) THERMOSTAT...
It SHOULD not be getting that much RESIDUAL heat
(possible plenum failure... but hopefully just the switch).
Here you have to ask yourself...
Is IT TIME to get your heater
PROFESSIONALLY inspected...
Pacific Gas & Electric used to do that for FREE...
but in this new, improved UTILITY climate
we enjoy today... I doubt they''ll do more than TAKE OUT
a few blocks in SAN BRUNO for FREE anymore...
(you might want to check...
(Same DEDIATED workers w/ really poor Management)).
(My opinion: FAT CAT, CRONY, bought & well-paid
EVIL/corrupt Government "oversight" (CPUC)).
There SHOULD also be a HIGH TEMP
fuel shut off "SAFETY" thermostats..
All these should only be handled with skill & knowledge...
as GAS APPLIANCES can be quite dangerous in the
WRONG HANDS...!!
I am just saying...!!
I'm here daily... Comment me back if unclear.
Happy hunting.
Carnac the Magnificent Y
Mar 12, 2017 | Ruud UBHC Air Conditioner
I have a Ruud UAKA-037JAZ central heat and air unit (Silhouette 11 gas furnace). When I turn the thermostat to heat the heat does not come on. I removed the front panel and there are 2 green lights lit up...
Need furnace model number. It sounds like you're looking for a standing pilot. Your furnace might not have one. Very likely to have a spark ignition type system or hot surface igniter.
Feb 01, 2018 | Ruud UAKA037 Air Conditioner
Make sure filters are clean . if they are stopped up the unit will over heat. Lets start there. Russ
Mar 22, 2010 | Ruud UBHC Air Conditioner
Sticky manual gas valve
Sounfds like the thermostat is on the blink.?
Oct 17, 2009 | Heating & Cooling
Blower fan is not coming on
I recommend you getting service its a safety thing. the humming is the transformer and is normal.. good luck Tom
Jun 22, 2009 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
483 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
