Kenmore washer series 70 shakes wildly during spin during cycle
My kenmore washer series 70 shakes wildly during the spin cycles. I took it apart a few months ago and could not see anything wrong or broken. Put it back together and it did not shake anymore, until last week. I took it all apart again, saw nothing wrong again, no springs missing or broken, etc.... I put it back together. It still shakes and walks across the room wildly during the spin. It is quite level. I literally have to sit on top to keep it from moving around. I noticed that the tub moves very easily from side to side and front to back by hand, but it may have always been that way. It doesn't shake when the tub is empty spinning, but with a few items or a full tub, it shakes wildly. It is a model 110.92272100 serial #CC0885890. Suggestions? Thanks.
  • 1 more comment
  • DawninAnnap May 21, 2008
    I have a maytag and its spinning wildly and the small clear hose internally pops off and has flooded my laundry room. The basket can be moved very easily when its not on...any suggestions?
  • robert samples May 11, 2010
    can you spin the tub easy with the washer off
  • Anonymous Mar 26, 2014
    About a week ago the machine got real loud during the spinning cycle then today it was spinning and the tub started bouncing of the side of the machine and all the springs are still attached
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Posted on Aug 09, 2008
6ya staff
SOURCE:
Washer shakes bad during spin
Could also be the drum bearing has collapsed or about to
Apr 28, 2017 | Kenmore Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore 70 make ratchet noise ,will not
Probably bad lid switch. Your ratchet noise is normal during the wash cycle.
Mar 24, 2009 | Maytag PAV2300 Top Load Washer
Water won't drain
This is usually caused by the lid safety switch. When the switch malfunctions, The washer believes the lid is open and the washer will not spin or empty. The switch is intended to prevent injury during the spin cycle. The timer could be bad but it is usually the switch..
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
90 Series Top Load Washer shakes during spin cycle
The Guide Plate underneath is out of alignment,, You might have to call me on this one. The only reason I am sure of this is because when my delivery guys would deliver a direct drive washer such as your, sometimes when the machine is laid down to far on its side, it gets out of alignment. Easy fix,, Just hard to explain.
Mar 24, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washer 70 Series shakes badly during spin after repairs
make sure that the 3 corner triangel thats betwwn the tub support and the base is in the right position all 3 parts corners should be pointing the same way
Mar 03, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
You probably have a bad lid switch.
May 21, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
2,048 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
