Question about HP LaserJet 4350n Printer
My printer has slowed down drastically in print speed. Can I speed it back up? This printer is on my local machine (not networked) and it has lost a lot of speed when attempting to print paychecks.
2 Suggested Answers
SOURCE: My printer has slowed down drastically in print
I called the company that makes my printer - it's slow now too. After the tech conferred with others, they all concluded that my machine is on its way to dying. Hope that's not your story. (23 Mar 2010)
Posted on Mar 23, 2010
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
Printer takes forever to print
How is the printer connected to your computer(s)?
If it is USB or network. Try a different cables.
Does your computer run slow also? Low disk space can cause print jobs to print slowly.
Network issues can cause slow printing as well. If your printer is on network and there is a mismatch of 10/100 Mbps speed or Half/Full duplex, the printing can be slow.
If your OS is Windows, remove the printer from Printers and Faxes. Uninstall the driver package if installed separately. Download the latest drivers and install them and reinstall the printer.
Apr 15, 2013 | Lexmark MS310dn Monochrome Laser Printer...
Looses connection with network
Common for this printer. Instead of setting it up as a network printer, attach it locally to a machine and share it. It will be much more stable.
Aug 09, 2012 | Lexmark T620 Laser Printer
HP P3015 suddenly printing very slowly - about a page a minute
If you unplug the cable from the printer to the PC and print the MENU MAP, does it print slow or at normal speed?
If it prints slow, try following the directions below.
If it prints at normal speed, try removing the printer from the print queue and reinstalling it. Also, download the PCL5 drivers and reinstall it.
Good Luck.
Print a MENU MAP and a CONFIG page.
You will need this info to put the settings back in the printer.
1. Turn the device off.
2. Turn the device on. When the memory count begins, press and hold the CHECK MARK button. Continue holding
down this button until all three device control-panel lights flash once and then remain on. This
might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the ^ button
until COLD RESET is highlighted.
4. Press CHECK MARK . The device performs a cold reset and then continues its power-on sequence.
5. Check all I/O settings and reset any customer-set device configuration values.
COLD RESET sets ALL control panel menu items, including network settings back to factory defaults.
This is where the MENU MAP and CONFIG info come into play.
Feb 09, 2011 | HP P3015 Laser Printer
Canon 3300i prints / process very slow
These machines can print slowly for a varity of reasons. First and foremost is using the incorrect driver. The correct driver can be downloaded here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2275&modelid=6349
Also slow printing can be a symtom of a hard drive about to fail (e602 codes).
Fastest printing speeds can be achieved using the following basic assumptions:
1) The copier is printing thru a standard cat5 cable; not thru the parallel port.
2) The network the copier is on is healthy and operating normally.
3) The network settings on the copier are configured correctly.
I am a Canon trained authorized tech on these machines and have been working in the field on the ImageRunner 3300 series since their release. I'm not sure if a ram upgrade is available but I haven't installed one in the six plus years of servicing this machine to fix a slow print problem.
Nov 09, 2008 | Canon imageRUNNER 3300i Printer
PRINTING PROBLEM
Hi if you are using MS Windows NT based OS when you install the printer do not forget to assign a fixed IRQ else the system waits to allocate a free IRQ at its own time which slows down your comp drastically.
Apr 10, 2008 | IBM eserver xSeries 220 8646
Optra T614 printer
i had the same problem and it went away after i removed the main circuit board and reinstalled it. (left side of the machine)
Apr 03, 2008 | Lexmark Optra T614 Laser Printer
HELP printer is haging up computer
To me, it looks more as a network problem rather than a printer problem. Just to make sure, delete every unused printer drivers from your computer, including the SCX-4521f. Unused printer drivers take up memory and CPU resources of your computer, even if they are not being used. The second common issue on slow computers is an excess of installed fonts. If you have more than 300 fonts installed, you need a cleanup.
Finally, install the SCX-4521 as a local printer only on your computer and print some tests. If they come out at decent speed, get a real computer technician to diagnose your network. If it doesn't, you need to further clean your computer's registry. It is most probably loading drivers, data and files from deleted applications. You can download a very good cleaning utility called Ccleaner on the Internet. Also check for possible virus using Panda or Kapesky antivirus. Good luck.
Oct 26, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Sharing srp350 network printer on win98 to winxp
You are correct with the conflict, although, it's a difference in drivers, i think what has happened is when you share a printer with xp, it installs the driver from the pc with the driver and printer attached, and as it is attached to a win98 pc, the full functions are probably unavailable,unlike an xp local driver.
Mar 06, 2007 | Samsung SRP 350 Thermal Printer
HP LaserJet 4350n Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
