Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover steam vac has no suction blowing air from middle of bottom
2 Suggested Answers
  • 190 Answers
SOURCE: hoover steam vac has no suction
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Make sure the tank lid is aligned to the recovery tank to seal, and assure the square panel is in place on the front of the recovery tank that connects the vacuum of the tank to the clear nozzle plate.
Posted on Mar 23, 2010
My hoover steam vac will not **** up the water on the carper.
the lid on the tank is not on properly or the duct/block that fits in the front of tank is missing..
May 05, 2010 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover steam vac has no suction, blowing air from middle of bottom
Mar 22, 2010 | Hoover SteamVac F5914-900 SpinScrub...
No suction in new Hoover Steam Vacs
http://www.hoover.com/pdfs/manuals/F5914900.pdf hopefully this helps
May 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac not sucking water back up i have super wet floors and no water in recovery tank
I think it is the gasket on top and bottom of the plastic chanel that takes the water up to the dirty water holding tank , Part of the rubber gasket is missing on both the top and bottom. This will alow
air to come in and thus you loose the suction to empty the water into the dirty water bin. My unit is hoover steam vac model F60220-900. I need to know where to get the gaskets.
Aug 28, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hi, i have a hoover steam vac agilty. the brushes on the bottom front quit spinning. they are not locked up as i can freely turn them by fingers. is there a belt that i need to replace? if so, how do i get...
The brushes on all hoover steam vacs are air opperated it uses the suction of the vacuum motor to spin a turbine and in turn spin the brushes. Most likely that path of air is clogged with hair or carpet fuzz. On the top of the machine there is a little clear cover undr that cover there is a screen which keeps that hair for entering the turbine kinda like you clothes dryer lint trap. Take the cover off and clean that screen this should help. If you have any other questions or need parts for that machine or any other visit www.stevessewandvac.com
Aug 12, 2008 | Hoover Vacuums
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
73 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
