Question about HP Pavilion a350n PC Desktop
Clock in computer will not maintain time and date
I have a hp Pavillion desk top computer model a350n. The clock in the computer will not maintain correct time and date if power is removed from computer and then repowered the next day. Time reverts to 1/1/2001 1:00 am. If power remains to computer after computer is turned off date and time are correct on startup. What is the cause? Is there a cmos battery inside the computer? Would a dead cmos battery cause this? Would there be other obvious problems if the battery was dead? Where would it be located inside?
  • 86 Answers
Yes it very probably is the CMOS battery, time is kept counting electric pulses, when the computer is turned on there is power and memory to do this, but when it is turned off it relays on the battery to keep this an some other settings, maybe you're receiving a warning at boot time. Check this guide for replacing such batteries:
http://www.computerhope.com/issues/ch000239.htm
Posted on May 15, 2010
2 Suggested Answers
  • 1335 Answers
SOURCE: Clock in computer will not maintain time and date
There is a wafer lithium battery that maintains the power onboard the motherboard to maintain settings. The batter is located on the top side about midboard. Open the side of the computer case so that you have access to the motherboard. Before you remove the battery, you may want to carefully vacuum out the dust in the case and then use a can of air (available from Radio Shack or comuter supply store) to blow out the remaining dust.
You will need a replacement CR2032 Lithium batteery.
To replace the battery:
1 Remove the side panel that has the thumbscrews. See page 99.
2 Gently lay the PC on its side.
3 Remove any cabling, if necessary, to reach the battery.
4 Remove any memory modules, if necessary, to reach the battery.
5 With a flat screwdriver, press the metal latch that holds the battery in its
socket away from the battery. The battery will pop out.
6 Install the new CR2032 battery in the socket, with the positive (+) side
facing up.
This should take care of your lost date.
Please rate this solution. Thanks.
Posted on Mar 22, 2010
Testimonial: "kitajib answered my question and solved my problem within 1/2 hour of posting my problem. He was able to tell me how to access the part."
Compaq nx6110 no clock setting in bios
Set the date and time from the bottom right hand clock icon on your desk top.
Nov 30, 2015 | HP Compaq nx6110 PC Laptop
How to replace desk top battery in HP Pavilion a350n PC Desktop
normally a professional technician should be able to replace the battery, if you follow this link you should be able to replace it as well, good luck.
http://support.hp.com/us-en/document/bph04375
Apr 27, 2014 | HP Pavilion a350n PC Desktop
How to set time and date?
Automatically Set Computer Clock
It's really upsetting when a once reliable computer starts to lose time.
Most of us rely on our computer clock to keep us aware of the time spent on the Internet or working on a project on the computer.
So, time is important.
Here is a way to configure the computer so that it automatically synchronizes the time with a time server.
Note: You have to be online for the synchronization to take place.
The first step is to open the date and time dialog box located on the task bar on your computer. Should be on the lower right side of the task bar.
Right click or Double click time to open the dialog box.
The date and time box should open on the desk top.
Now click the Internet time tab.
Check the box that says automatically synchronize with an Internet time server.
Then you will see a list of servers.
Select a server from the drop down list.
Check apply and close the box.
Now every time you go on the Internet Windows will automatically set the computer clock to the right time.
Now, there is no need to worry about adjusting the computer clock again!
Jul 26, 2013 | HEWLETT-PACKARD HP 4500 All In One Printer...
How to set time
It's really upsetting when a once reliable computer starts to lose time. Most of us rely on our computer clock to keep us aware of the time spent on the Internet or working on a project on the computer. So, time is important. Here is a way to configure the computer so that it automatically synchronizes the time with a time server. Note: You have to be online for the synchronization to take place.
The first step is to open the date and time dialog box located on the task bar on your computer. Should be on the lower right side of the task bar. Double click time to open the dialog box. The date and time box should open on the desk top. Now click the Internet time tab. Check the box that says automatically synchronize with an Internet time server. Then you will see a list of servers. Select a server from the drop down list. Check apply and close the box. Now every time you go on the Internet Windows will automatically set the computer clock to the right time. Now, there is no need to worry about adjusting the computer clock again!
Feb 09, 2013 | Computers & Internet
Call display
Double click time or right click to open the dialog box.
Hope this helps.
Nov 18, 2012 | Computers & Internet
How to set time on model HD211B clock radio
1: Remove screw from top back of radio and carefully lift lid that retains buttons. Might be a good idea to take a pic of buttons so they don't get mixed up as they will just pop off at this point.
2: On either side of the back middle button you will see a switch and three (3) buttons.
3: Move "Off On Lock" switch to "Off" (left) position. You will see the unlocked symbol appear on the display.
4: Push far right button first to set your time "Zone" using the "Alarm Time" or "Radio Tune" buttons. Wait 5 seconds for the beep when done.
5: Push the "Time Set" button. (It is the one closest to the "Off On Lock" switch).
6: Use the "Alarm Time" or "Radio Tune" buttons to set the time. (Note: "PM" will appear in the upper left corner of the front display when your time is after noon!)
7: The time display will stop blinking and set about 8 seconds after your last move.
8: Push "Calen" button to set calendar. First the year the push the button again to scroll to the date.
9: Push the lock switch to the right and the lock symbol should disappear from the front display.
10: p
If you removed any buttons put them back, then put the cover back on and re install the screw.
or
Call the front desk and ask them to set or replace the clock.....
Oct 17, 2012 | Audio Players & Recorders
Setting time on wincraft desk clock
Directions for Desk Clock - Without the C?/F? button
To change the Temperature:
Press the "S" button once (this will change from Fahrenheit to Celsius)
To change the Time and Date:
Press the "M" button once to change time to or from military time
Press the "S" button once to change the hour
Press the "S" button again to change the minute
Press the "S" button again to change the year
Changing the year will also change the day of the week
Press the "S" again to change the month
Press the "S" again to change the date
To set the Alarm:
Press the button with an alarm clock on it
A flashing 12:00 should appear
Press the arrows to set the hour
Press the "S" button again to set the minutes
Press the "S" button again to change the "ring" of the alarm
There will ne a number below the time the alarm is set for
Use the arrows to advance through the options
To turn the alarm functions completely off:
Press the button with the alarm clock on it
Press the "S" button five times
When three dashes appear where the time would be, it is off.
Press the "M" button three times to get back to the main clock function
To clear the secondary clock:
You can set two different times on the clock, so if you travel frequently you can have a home time with alarm and a travel time with alarm saved and ready to go. There is a primary time, the one you normally see on the clock with an alarm clock function after it. There is also a secondary time with an alarm function after it.
Clearing the secondary clock will make it easier to know when you get back to the primary clock function.
Press the "S" button seven times
Press the "M" button two more times
And you are Done!
Jan 02, 2012 | Wincraft FLORIDA GATORS OFFICIAL THE SWAMP...
You need to replace the CMOS battery--a flat battery about the size of a quarter.
When you open the case, you will see it attached to the motherboard. Use caution when removing it from the holder--one side usually has a little tab that you can push to one side to release the battery.
You need a #2032 battery.
Mar 22, 2010 | HP Pavilion a350n PC Desktop
How to change settings of Seiko world time alarm & desk clock
I have the user manual for this clock for anyone who sends me his e-mail address.....
indysandy@indy.rr.com
Feb 03, 2010 | Watches
Computer clock
u can try using YAHOO WIDGETS from widgets.yahoo.com
u can find lots of clocks that sync with the online server of the widget itself.. in some clocks u can also set a reminder for nething u want.
or u can www.worldtimeserver.com to sync ur windows clock with it. u can find the details of how to sync the clock in the F1 option of ur HP. just press F1 for HELP and type in ur query,it'll guide u with the styeps. if ur using Vista on it then the Vista clock syncs it self with the time server.. u can see it by double clicking the clock in the taskbar at bottom right corner where the clock is.
PLEASE RATE ME,WOULD APPRECIATE IT
Aug 09, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion a350n PC Desktop Logo
262 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
