Question about Refrigerators
Top fan of Haier HVTS18 stopped and temperature is very high
3 Suggested Answers
SOURCE: need cooling fans for haier
http://www.repairclinic.com/PartDetail/Fan/1222948?modelNumber=HVW18ABB
Posted on Mar 09, 2011
imufo2
  • 3773 Answers
SOURCE: My Haier HVW18 Wine Cellar has a top fan which
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 27, 2011
MODEL #HAW18ABB
www.haier.com/us/servicesupport/overview
Jun 11, 2014 | Haier HVTS18DABB Wine Cooler
The top fan is not working and is heating up top compartment. The fan seems to be stuck.
remove the back metal panel and unscrew the top fan and unplug the terminal the cable plugged into the board. I spread disc brake cleaner and then wd-40 into the coil area with a fan spins. manually spin the fan with your finger a few times to get the lubricant evenly distributed. I had the same with my top fan and if the same
Mar 17, 2013 | Haier HVTS18DABB Wine Cooler
Wine fridge is always running but never cools below room temperature.
the processor cooling fans for the CPU and case fans are 3 PINS.. you can use them but remember that these are 12V fans. once its the same power it will work. Ps if needed you can cut the connects from your old fan and connect it to the new ones to get it to fit properly..
Dec 30, 2012 | Haier HVTS18DBVS 18 Bottle Dual Zone Wine...
Have a a/c hwro6xc7 will not turn on error code e-1
I hope that you have the remote for the unit. The error code merely means that you have to reset electronics.
If you do not have the remote, believe it or not, some VCR/DVD remotes will work the system. The remote instructions are for a 'One For All' URC-3021B00 universal remote. The Haier remote will use the conventional buttons.
The buttons are as follows:
rewind=power on/off
pause= timer on/off
4=low/high
5=temperature up
9=temperature down
8=fan/cool
Jun 12, 2012 | Haier Heating & Cooling
WHERE IS THE TEMPERATURE CONTROL FOR THE HAIER........AND HOW DO YOU REGULATE THE TEMPERATURE. I PLUGGED THE HAIER IN AT 7 PM ON 1-4-11 AND CHECKED THE TEMPERATURE AT 8 AM 1-5-11 AND IT WAS 24...
Sorry to read about your problem, I hope this helps you out.
the freezer adjustment, is in the refrigerator at the top
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Haier HTE18WAA Top Freezer Refrigerator
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
Temperature light is flashing red, coolant is
fan relay is under the frame on the left by the fans. but most likely the fans themselves have gone bad check the fuse panel on top of the battery see if it is burned or blown fuse this is caused by the fans going from stop to high speed to many times. you will flat 40 or 50 amp flat blade fuse and both fans sorry for bad news
Sep 01, 2009 | 2001 Volkswagen Beetle
Dehumidifier
Dear rmclpc
huuum at your service.
Here is a site offered by fixya.com for owners manuals.
http://www.pronto.com/user/search.do?displayQuery=
kenmore%20elite%20oasis%20owners%20manual&SEM=true&query=kenmore
%20elite%20oasis%20owners%20manual&adid=1210312579-6519660d_10_gc&ref=
owners%20manual&creativeid=1167763135&site=
www.fixya.com&loadingComplete=true
Bless You,
huuum
Please give me a good rating before you sign off here at fixya.com
Sep 17, 2008 | Maytag M7DH45B2A Dehumidifier
Haier
In units with physically separate sections, there is a fan that circulates the cold air between the two with some provision for adjusting the airflow to balance the temperature between the two chambers.
The cooling system is normally a totally closed loop that is charged in the factory through a nipple that is then pinched and welded shut.
This nipple must be cut and resealed to recharge the system.
Jun 01, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Freezer fan is not working
the fan may be jammed due to ice build up. in the first instance i would give the unit a full defrost for 48 hours then see if the fan starts after, if not the fan motor may be u/s.
May 31, 2007 | Haier HTQ21JABWW Top Freezer Refrigerator
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
