Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Hard Drive doesn't show up
I have a new Imac, with OS 10.5.2, using my Acomdata HD as a backup with the Time Machine function. It was working fine for a few days, but the HD is no longer being recognized by my computer. The HD is on (steady blue light) but it doesn't appear on my desktop (I've tried my laptop as well, with no luck). I've tried all sorts of combinations: plugging it in after the computer is turned on, plugging it in before it's on, turning the HD off and then on again, etc. Please help!
  • Antdog5 May 14, 2008
    I also have the same problem although my mac is a little older/
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Good Luck.
Live, Love, Laugh.
Posted on May 14, 2008
SOURCE:
How to replace solid state hard drive on imac computer
Hi Felix
Pretty simple really.... once you get the iMac opened!
See below
Simply find the existing hard drive, disconnect and slip it out.
You might have to remove a couple of screw in locating studs from the old drive and add to the new drive.
The connectors should match up with the existing cable.
Called SATA (Serial ATA)
The temperature sensor is stuck to the outside of the drive, carefully peel it off and stick it on the new drive.
Use Carbon Copy Cloner (CCC) to make a clone copy of your existing drive or install a new OS X (Downloadt off Apple Site)
Good Luck
I'll assume you know that Maverics, Yosemite OS X are free to download. And the latest El Capitan is due in Days.
Resources:
Mac Backup Software
intel iMac HD install
Sep 17, 2015 | Apple iMac 24" Desktop
My personal Macbook pro died, but I did have a Time Machine backup. I have a new iMac that I would like to use as a family computer. I would like to transfer some files to the new computer (and set-up a...
The best approaches is to buy a 2.5" usb sata drive case. Remove the hard drive on the macbook to get back your files and folder on the new imac. Use the drive afterward for time machine
Aug 03, 2013 | Apple iMac Computers & Internet
Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My iMac (OS X 10.6.8) no longer recognizes my G-Tech 500G external hard drive. Time Machine noted that a backup had not occurred for 10 days and so I turned the disk off and then back on (this generally...
The drive has probably gone, but what I would try is make sure that it is not a cabling or port problem. First try the cable that you have been using in another usb device (one that you know works) and see if that works, that will prove that the cable is functioning properly. If that does not work try the cable in one of your other usb ports. If you are funning it as a firewire device do the same with firewire as above. If these work then it is more than likely the hard drive is gone.
If the drive is under three years old as far as I can see the G-Tech external hard drives are covered with a three year warranty see http://g-technology.com/products/g-drive.cfm get in touch with the manufacturer and claim under their warranty.
Hope this helps.
Sep 11, 2011 | Computers & Internet
I have been running my Acomdata external hard drive on my imac intel for some time now. Formerly, I used it on my G4 Powerbook. The motor has always been a bit loud, but it has always performed well. I...
Backup when you need from the drive, and then do a full re-format. Don't do quick format. If that doesn't solve it, the drive is dying and I wouldn't trust it anymore.
May 05, 2017 | Acomdata (HD060U2FE-72) 60 GB Hard Drive
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
ACOMDATA 250
I have the very same problem than the one posted by gyoung826 on Aug 14, 2008. My HD is an Acomdata 160 GB, HybriDrive 2,5
Aug 14, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
Won't mount
Western digital drives ****! I'm having the same problem repeatedly. Seagate drives work fine though.
May 30, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
179 people viewed this question
Top Acomdata Computers & Internet Experts
Ekse
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
