Question about Epson Stylus CX3200 All-In-One InkJet Printer
Cant find out how to clean the head i have horizontal banding and colours are funny
    Problem Solver:
  • 19 Answers
Hello !
I will give you a number of reason or solutions that I hope will help you .
1. All of your printer heads are bad and its not helping if you clean them because maybe you havent been printing for a while the heads get dry.
2. Somewhere in the printer program installed on your computer there should be a helping program for cleaning. If you find it then the printer should tell you when the cleaning is done but the only problem with that function is that you are losing a lot of ink.
3. This is a solution that could work if the cartridges are dry. Take away the cartridges from the printer and put them on a dishcloth contains lukewarm water. Just for a few seconds untill you can see its clean because you dont want to destroy the electronic parts on the cardridge. If its working you will see the ink drain into the dishcloth or paper. Wait for the cartridges to dry completely and then put them in the printer.
4. If none of this reasons will help you need to buy new cardridges.
Good Luck
Best Regards
Joakim
Posted on May 18, 2010
Banding on printer
Horizontal banding or vertical banding?
Vertical banding : clog in head. Do nozzle check & head cleaning.
Horizontal banding : Do head alignment
Sep 30, 2013 | Epson Stylus Office Equipment & Supplies
When I print in colour, it prints the image, but in coloured horizontal bands
There should be an option on the printer to clean the print head. Try that
Mar 07, 2011 | Epson Office Equipment & Supplies
HEAD CLEANING DOES NOT FIX GAPS IN NOZZLE CHECK
Head cleaning is for fixing horizontal band. If some point of head cloged, print out will show horizoantal banding. For vertical banding, try using head alignment. Have yo tried printing without high speed (disable high speed option)
May 20, 2010 | Epson Stylus C84 InkJet Printer
Cant find out how to clean the heaD i have horizontal banding and colours are funny
Press one of the Menu buttons repeatedly until Head Cleaning appears on the LCD panel, and then press the Color Copy button.
When the On light stops flashing, print a nozzle check pattern to confirm that the head is clean and to reset the cleaning cycle.
Press one of the Menu buttons repeatedly until Nozzle Check appears on the LCD panel, and then press the Color Copy button..
For further instructions read user manual.
Mar 23, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Horizontal banding on prints
try aligning the print heads before cleaning them
Oct 10, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Black bands on picture
5 black bands means dirty heads. try a sony cleaning tape; if no good, time for hand cleaning.
Sep 19, 2008 | Sony DSR-30 Mini DV VCR
Epson Photo R265 Lines every 2.5 cm
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
cx3200@tiscali.co.uk
Dec 17, 2007 | Epson Stylus R265 InkJet Photo Printer
MP700 Magenta horizontal stripes
I have the same problem. Here's the advice I found somewhere on the internet:
If a jet (nozzle) in your cartridge has gone bad you will see horizontal bands and/or white streaks in your print. Print characteristics may appear incomplete and/or the filled in areas on may not show up.
1) Run some warm water over the print head. This can wash away any ink which might have dried in the cartridge print head. Dry the cartridge with a lint-free cloth before placing back into the printer.
2) Clean the contacts on the cartridge (the copper colored circuitry) and the contacts where the cartridge clips into the printer with water or alcohol. After cleaning, insert and remove the cartridge from the printer a few times to be sure you have a good connection between contacts on the cartridge and the printer.
3) If your print is smeared cleaning the wiper blade may fix the problem. Do this according to your printer manual instructions.
Nov 25, 2007 | Canon MultiPASS MP700 All-In-One InkJet...
Colour printing
If the test patterns are not matching what your printer tells you is normal and your photos are banded horizontally, you may have clogged nozzles and printhead. Do a maintenace clean under your printers direction, and see if it now prints ok. Also, you may be low or out of one particular colour, but still have enough of the others and the printer will try to compensate by using available colours, hence colour banding and distortion. A manual clean with cotton buds and cleansing solution is recommended if the first clean does not help.
Dec 12, 2006 | Canon BubbleJet i560 InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
