Question about Kitchen Appliances - Others
I want circuit diagram of mosfet based preamplifier for fm radio dxing
4 Suggested Answers
SOURCE: sharp wf 940 portable cassette / radio player
inside radio there is relay near power supply. change it and then radio will work. or clean it.
Posted on Mar 20, 2008
SOURCE: circuit diagram for alinco vhf base dr112t/e
respected sir,
you may find some idea here
http://www.eserviceinfo.com/
AK
from Bangaluru
Posted on Aug 27, 2008
  • 212 Answers
SOURCE: Clock is running but fm-am radio is not playing.
you need to change the circut board...
Posted on Jul 23, 2009
Am fm power to high keyup 60 watts ssb works fine mosfet 2030
If SSB works. then the AM - Regulator Transistor is bad.
Feb 15, 2014 | Magnum S9 Base CB Radio
D104 wiring
TUG 8, TUG 9, TUP 8 or TUP 9? What radio? If it's a pre-amplified or power mic, there is a screwdriver adjustment under the base and a 9 volt battery in the base. The battery could be dead or the mic is turned down. If it is not a preamplified D 104, it wont be loud unless you run it on a Tram or Browning Tube Radio that accepts a high impedance mic. I hope this helps. :-)
Feb 13, 2014 | Radio Communications
NO variable power on FM,or SSB, but variable works ok on AM
Look for open resistors near by, if the 2SC1969 shorted it has taken out one or two parts, also check for open foils on the printed circuit, beyond this a circuit diagram is needed.
Mar 23, 2012 | Magnum S9 Base CB Radio
How to conect to the radio
It will depend on the radio design as to exactly what components to identify as landmarks.
In general, you want to locate the preamplifier stage, and this can even vary by type of circuit. Sometimes you can tap the circuit at the volume control, other times you have to locate the point after the detctor stage which is the stage with the typically glass diodes. Often a single detector diode for AM and either 2 or 4 detector diodes for FM. You can try at this point of the detector. If you touch the solder track with a metal screwdriver and hear a buzz- it helps if you are working near a flourescent light.
If the output circuit is an IC chip, locate the input and try there. Your results will work best with a low impedance microphone.
Dec 18, 2011 | Audio Players & Recorders
My sony icf 7600 AM/FM/SW/radio can not catch any channel.when i turn it on,its speaker give narmal on sound ,LED also works,prequency can b fixed in it ,but can not receive or catch any channel.where is...
Sony radios of this era had notorious capacitor problems.... also several other brands were affected. These capacitors were underrated and the technology to make them was not at it's best back then. The cure is to replace the capacitors on the board with new electrolytics. About 28 of them need to be replaced but the big problem is to find someone to do this. the original capacitors are surface mount and must be removed and new radial lead caps put in their place, some are rather tough to get at and the new ones have to be placed carefully. My SONY ICF-SW7600 now works as new and maybe even better!
I have done this myself as I have skills working with surface mount capacitors. I offer my services to those who cannot find service for their radios. Please email me for details, I am not into making bucks on this, I just want to see these radios kept working and bringing enjoyment to their owners.
Good DXing Rod KB8DNS (also copied and paste)
Mar 18, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
My sony icf 7600 have speaker on sound when i turn on my radio,but it can not catch any AM or FM channels.where is the problem, and is it can be solved.no one know about it in my country Pakistan?
Good DXing Rod KB8DNS (copied and paste)
Galaxy 99 v
Likely the radio has a blown detector diode on the board as FM uses a special demodulation detection circuit called a quadrature detector or a discriminator detector the SSB circuit uses a product detector so the only other thing used in detection is the Am detector Diode. That is the first place to look if it is not bad it will be somewhere in that circuit.
May 07, 2008 | Galaxy Radios DX-99V 40-Channels Base CB...
Sharp wf 940 portable cassette / radio player
Mar 01, 2008 | Sharp CD-BA2600 CD Shelf System
Switching radio bands
what radio do you have? does it even have sideband channels? some radios don't come with them, of fm or upper or lower side bands and short wave
Dec 08, 2007 | Connex 3300 240-Channels Base CB Radio
Kitchen Appliances - Others Logo
41 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
