Posted on Mar 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a yamaha home theater system and when i turn it on with no speaker wires in it it says on the front of the surround sound system speaker error is there anyway to fix the problem thank you scott
Anonymous
Level 2:
Scholar:
  • Expert 130 Answers
  • Posted on Apr 02, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
130
Questions
0
Helped
352414
Points
292
There could be a small piece of wire crossing where you hook up the speakers that might have came off and is causing a short
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Yamaha DVX-S100 Theater Sound System
check your surround sound settings. Switch the speakers and test it again. if the problem persist, take it to your store and ask them to test it.
How to solve a W 1 error on a Yamaha HTR-3063
Are we really talking about a HTR-3063?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-3063-Receivers-manual/id/23653ag915/t/2/
Strangely enough, that message is NOT documented in the HTR-3063 manual, but in another Yamaha manual (HTR-5063) it means the speaker being tested is believed to be Out of Phase, meaning wired incorrectly.
Your unit (HTR-3063) doesn
My surround sound shut off and sound went to tv as it's output source
try unplugging it and pluggin it back in. and make sure no wires are touching that would make it shut down.
Speaker Err on Yamaha Home Theater Unit ???
I am assuming this is the message that shows up from your receivers front display panel? It could be the receiver is telling you that you may have the neg & pos. wires crossed and in the opposite position either in back of the receiver speaker posts, or in back of the speaker terminals themselves. My Yamaha receiver has this nice feature where it will tell you when the speakers are "Out Of Phase" which describes the problem I have described here.
Just go back and make sure your wires are hooked up correctly, and use tape and a Marker to label pos. and neg so they will be easier to hook up next time you have to move the system, or decide to change some aspect of your system. I would then take the time to label every wire that goes to each speaker that you plug into the back of your receiver. This a BIG time saver........
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
2answers
Help installing Yamaha home theatre system.
This is probably a setting problem on your remote-the unit will ony give full surround sound on Movies like dvd-on TV you may not get all speakers going as the cable does not provide signals to drive all speakers-check your manual and change to the appropriate setting-pro-logic is bad for this-will not give sound to all speakers unless the signal tells it to.
 Grubhead
Grubhead
SmartAviator
SmartAviator
