Question about Vestax Pdx2000 Direct Drive Turntable System
Vestax PDX200 platter keeps changing direction
Hi, I have a Vestax PDX2000 deck which occasionally stops in the middle of a record and starts playing backwards for a few seconds then starts playing forwards again. Obviously this makes mixing impossible. Any ideas how i could resolve this?
  • 2 more comments
  • Anonymous May 11, 2008
    have the same problem any1 know where i can fix this
  • Anonymous Dec 11, 2008
    man I have the same dam problem! anyone know a fix. i took it to an electronics shop and they werent able to do anything for me!
  • marcusbarkus Apr 10, 2009
    as im am mixing either side randomly stops and changes direction then go's foward again. its making mixing a nightmare can any help me with a solution? please please
  • Anonymous Apr 23, 2009
    Dude I have the same problem and cant find solution, anyone seen spare motors for sale ???? im so annoyed that i just want to replace the motor!!!!
Hi everyone,
I had exactly same problem with my Vestax pdx 2000 mk2 TUNETABLE.
The solution involves some careful screwdriving but is fairly simple....
You need to take the motor out and carefully take it to pieces, the problem is caused by a tiny piece that needs to be put back into place. Of course you will loose your warranty but its cheaper and faster then getting new motor or sending to repair.
If u need help don't hasitate to email me: [email protected]
i can explain every step and send u step by step pics of the repair.
Posted on Apr 23, 2009
  • recordandstk Jul 04, 2011
    I have the same problem. Good thing i found this page.
    New Friend:
    Problem Solver:
  • 5 Answers
This is a really common fault with this model of TT. I've just repaired a pair of them with the same problem.
You need to remove the bottom cover of the deck then take the round cover off the bottom of the motor assembly. Be really careful with that, delicate sensitive stuff inside. Once you remove the screws use a small flat blade screwdriver to lift the cover free of the rubbery glue that seals and holds it in place.
Once removed, in the centre of that cover is a small black rubber cirlce about 6mm in diameter that the shaft of the motor rotates on. The problem causing all of that erratic platter movement is with this small black circle.
The solution I found was to use double sided tape to hold this part in place. This serves two purposes. First, to stop the part from moving off its required location, Secondly, to raise the part up slightly from the bracket that it sits on. Layer the double sided tape up so its the around the same thickness as the small black rubber circle. Then place the black cirlcle into its original location bedding it firmly into the tape.
A tiny small dolop of grease on the end of the motor shaft. Replace the motor and bottom covers. Bingo! The decks a-go-go!
Happy mixing!
Posted on Jan 12, 2010
  • 3 more comments
  • Hendrik Prechtel Dec 08, 2010
    Sorry, I have a similar problem, but my English is not perfect. Bought two PDX 2000 on ebay and one has the problem that the platter vibrates and rumbles when playing. Can I fix it with this method and if so,could one please please please make some photos of how it has to be fixed? I'm not sure whether i understood everything here. In case of doubt I would say no. Please help!
  • scratchclear Jul 04, 2011
    i have the same problem. Padster07, I have a question, which cover do i remove? there are two different kind of screws, there are two smalls and silver two long screws, not sure which ones to remove. If anyone has done this procedure please reply if you can. thanks
    Sorry, which cover of the motor?
  • Anonymous Jul 05, 2011
    Hey. If you get in touch with jazzbin he has photos of the job at various stages.
    All the best.
    Pat.
    All the best.
    Pat.
    New Friend:
Padster07, I could kiss you!!! Your solution worked perfectly. One of my PDX-2000s had been virtually unusable for the last few years due to the back and forth platter problem but I followed your solution and it's now back to full working order again. Thanks very very much!.
Posted on May 09, 2010
  • 1 more comment
  • saronbamedi May 09, 2010
  • shortman24 Nov 09, 2010
    wicked stuff. mine has been sat in the cupboard for three years or more and i finally have a pair back! think its given me the inspiration again! NICE ON BRUVVA!!
  • Hendrik Prechtel Dec 09, 2010
    Hello,do you have a photograph of the fixed item brought into place? I can't imagine exactly from the description here.
    New Friend:
I'm having the erratic table issue (reversing and moving forward like it's possessed).... I am not savvy with equipment at all. When I took off the base and tried to unscrew the round part... I couldn't figure out how to pry off the rubber cemented part. Should I just hack at it? Is that even the right way to go? I need a video tutorial!!! eeee!
Posted on Jun 25, 2012
I once heard this can happen with mobile phone's causing interferance
Posted on Jun 24, 2008
  • Davor VenomOtrov
    Davor VenomOtrov Apr 12, 2012
    Need to remove botom, and unslolder 6 diods and replace 3 resistors from 840 ohms to 470 and it will fix the problem. [email protected] so will post a picture if anyone wants to know, i have done this a few times. THis is usualy manifesting when u start the motor and u put ure hand on the platter. the solution cost one hour of ure time and about 50 cents in parts
6ya staff
SOURCE:
The platter keeps spinning backwards any advise ?
Hello
Its internal motor control circuit control logic has the trouble. The control IC alongwith the retulator transistor should be replaced. OK.
Mar 23, 2011 | Vestax Pdx2000 Direct Drive Turntable...
Vestax PDX 2000 motor going crazy problem
hey, it will work with the tape solution but you gotta pay attention to the light metallic circle which is used by the light sensor (the small black one with cables on it) to estimate motor movement - first time i opened it and did the tape thing to the black rubber circle i eventually touched the light metallic circle and i think that caused it not working for me too
the light metallic circle must be totally clean and plain, do your best, but be sensible
Jul 09, 2010 | Vestax Pdx2000 Direct Drive Turntable...
I have problem with tonearm on my vestax pdx 2000 turntable , no connection with needle , but when I make contacts of the needle wet it sometimes help a bit , but I should do it always to make it work. ...
I'd be checking the weight and height settings of the tonearm. Heres a link to the manual for the deck. There's instructions in there about how to setup up the tonearm properly. Don't be afraid to experiment with it. Just remember, too much weight will wear out your vinyl really quickly. Not enough weight will sound like **** and skip easily. Have fun!
http://www.vestax.com/v/info/support/pdf_players_manuals/VOM-PDX-2000E.pdf
Dec 15, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Eratic platter direction and speed changes.
Have you seen this solution (Padster07's), it solved my problem: http://www.fixya.com/support/t477894-vestax_pdx200_platter_keeps_changing
Oct 06, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Vestax pdx 2000 motor problem
You need to remove the bottom cover of the deck then take the round cover off the bottom of the motor assembly. Be really careful with that, delicate sensitive stuff inside. Once you remove the screws use a small flat blade screwdriver to lift it free of the rubbery glue that seals and holds it in place.
Happy mixing!
Jul 09, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Pdx 2000 stylus calibration
Hi Misskit , i have a Dual turntable straight arm [Dual is the brand ] maybe you could visit their website and see if there is something similar to yours that you could get some specs from , i think they are still in business they are a German turntable manufacturer . happy spinning
May 24, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Pdx2000
see inside the pdx2000 main board & you see the fues
Feb 05, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Hi i have a set of pdx 2000 vestax turntables and i am having the problem of a speed jump when you cue or scratch the record it only happens sometimes also i have noticed a creeking noise when i am cueing...
Happy mixing!
Jan 15, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Open Questions:
See all Vestax Pdx2000 Direct Drive Turntable System Questions
Vestax Pdx2000 Direct Drive Turntable System Logo
2,419 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
